Alternator issue
Old Jan 20, 2016 | 09:44 PM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Alternator issue
My alternator finally crapped out on me. No tags on the unit itself except a little sticker that says reman Delco. I have AC and defrost so I'm assuming it's the 78amp. Problem is she's my daily and they are special orders and sell for 130 dollars. I would rather upgrade since my auido is growing. I was thinking about putting in one from a 5.0. V belt 94-99 amp. Direct swap? Any special modifications. I read somewhere the back plug in orientation is a little different but shouldn't be a problem. Is that true?
84 2.8l.
Old Jan 21, 2016 | 09:47 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Alternator issue
Not sure off the top of my head, but one sure way to find out is go to the parts store and compare them side by side. Then you will know for sure. If it was a newer serp belt set up I would know you can't, but being an older V-belt alt, I can't say one way or the other.
Old Jan 21, 2016 | 09:55 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Well the specs are the same size wise. Same bolt pattern same belt requirements. Only difference is the orientation on the back. Different clock? I read it's for the clearance. Someone else here posted about putting a v6 alt on his v8. And it worked fine. So I'm assuming it's works both ways.
Old Jan 21, 2016 | 11:16 AM
drdave88's Avatar
Engine: 6.0L
Clock it then, pull the 3(?) bolts, spin the body and put it back together so it sits correctly.
Old Jan 22, 2016 | 09:59 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
for anyone that wants to know. the 95 amp from the 5.0 works just fine.
same casing
85@IRocZ
Mar 15, 2017 05:57 AM
85@IRocZ
Mar 9, 2016 07:27 PM
alex722607
Jan 6, 2016 04:33 PM
tn_camaro
Jan 3, 2016 11:12 PM
FiVe KiLLZ
Brakes
Dec 24, 2015 03:38 PM
