3.1 Losing power or won't start
Old Apr 5, 2016 | 04:23 PM
czlowiekmucha's Avatar
Car: 1991
Engine: 3.1
Transmission: Automatic
Some Time ago I had a problem. I thought It was head gasket because It was losing power and shakes like a devil on idle. But first I've changed all ignition parts and IAC to new ones, didnt help so I've took down heads but gasket were good. Anyway I've put new gaskets and replace valves. But the problem continues and now it's even more because now it is hard to start sometimes. Like in the video above. Compression is correct above 115 PSI on each cylinder.
Could It be skipped timing chain? Or maybe valves not well adjusted?
Old Apr 7, 2016 | 11:11 AM
Car: 1991
Engine: 3.1
Re: 3.1 Losing power or won't start
Today I noticed the big cracks on the magnet in distributor, but it's happening the same on the secend one (left side) with small crack-but it's cracked alongside, Could it be this? Can I buy this part of the distributor somewhere, because I can't find it on Rockauto
Old Apr 22, 2016 | 04:56 PM
Car: 1991
Engine: 3.1
Have changed whole distributor with new module... didn't help...
Is my ignition allright on idle? Or loose timing chain?
Old Apr 22, 2016 | 06:55 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Are you saying that it is still hard to start and shakes?
Old Apr 23, 2016 | 03:31 AM
Car: 1991
Engine: 3.1
Yes, still having problem with starting and it's drivable only for the first 2-3 minutes after that loosing power. When Pushing pedal to the metal causing stalling. Sometimes small explosions in the intake or exhaust.
This is new distributor from CARDONE
But even after changing Everything (distributor, spark plugs, wires, module, cap, coil, IAC) in ignition system nothing gets better...
HELP!
Old Apr 25, 2016 | 03:44 PM
Car: 1991
Engine: 3.1
Old Apr 25, 2016 | 08:10 PM
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
I like the music.. haha
Glad you figured it out!
Old Apr 25, 2016 | 11:58 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Did that fix the problem?
Old Jul 9, 2016 | 03:31 PM
Car: 1991
Engine: 3.1
Actually it didn't.
Problem still in progress....
I've put more new parts like lifters, oil pump and temp. sensors, so now everything from the head gasket up top is brand new.
but now car doesn't have power right after the start, earlier it was only on hot engine.
Gas response working in slow motion, and sometimes missfire. From start on DRIVE it has problem between 1200-2200 RPM (missfires, weak acceleration, no torque). But I can drive it over 60mph no problem..
Compression OK on each cylinder
I'm out of options. Could it be torque converter problems?
Old Jul 10, 2016 | 08:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If the stock Multec injectors are still in the engine replace them. By now the coils are shorting out.
The ECM is also an area of concern as the '7730s get flaky. This causes all kinds of strange problems. Drop the ECM down and with the engine running rap on the case. Can also twist the case slightly.
See if that changes how the engine is running.
As for replacing the lifters and such, need to adjust the valves, not just torque the rockers down. I don't recall the number of turns past zero lash. It is something like 1-1/4 or 1-1/2 turns.
There are threads here on TGO about the rocker arm adjustment.
RBob.
Old Jul 10, 2016 | 10:29 AM
Car: 1991
Engine: 3.1
I've tried different set of injectors - no improvement
Lifters were adjusted correctly with 1/2 turn, nothing change after replacement.
In two weeks I'm gonna switch ECM to see if it helps., but I'm still thinking of torque converter ... Sometimes on the RED STOP light RPM's flowing and on a hot days smells like burnt clutch
Old Jan 5, 2017 | 02:18 PM
Car: 1991
Engine: 3.1
New injectors from Southbay - still no improvement
Changing ECM - no improvment, I think it even got worst beceuse 02 sensor flashes and it drives even worst
I've put 3third set of ignition wires and niew distributor with cap, - nothing changes.
On cold engine in first 2 minutes of driving is ok, after that some missfires and lost of power.
It only happens on cruising between 1800 - 2100 after few second in the floor and some missfires it runs like hell above 2000 rpm, but leg out of pedal and it's happening again.
I'm thinking about changing Transmission with converter, but is it worht it? No clue...
HELP?
Old Jan 5, 2017 | 03:39 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Hows the fuel pressure?
hows the cat? A clogged cat will cause those problems.
How about the egr valve?
Old Jan 5, 2017 | 03:41 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Vacuum leak?
Chase every vacuum hose.
Is the hose connected to the "cannonbal" vacuum reservoir?
Car: 1991
Engine: 3.1
Fuel pressure - don't remember but it was allright.
EGR is gone few years back and reprogrammed ECM.
Didn't think about cat... Hmmm
Originally Posted by W.E.G.
Vacuum leak?
Yeah it's connected to new bigger reservoir tank from Audi A6 thas it matter if its a little bit bigger?
Old Jan 18, 2017 | 08:21 AM
Car: 1991
Engine: 3.1
I noticed a oil spill almost everywhere where I park the car.
It's probably going from the cover with three screws (camshaft cover?)
1. Could it cause vacuum leak over there?
2. Is it only gasket or is there any bearings inside to change?
3. Should it be cork or metal gasket? On Rockauto there is only cork.
Old Jan 18, 2017 | 02:03 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Did you ever change the fuel pressure regulator?
Old Jan 18, 2017 | 02:11 PM
Car: 1991
Engine: 3.1
Yes. Actually I've changed fuel rail for used one, didn't help... maybe it is somwhere over there because often smells fuel during driving, how to check it? And does changing the Fuel Pressure Regulator Diaphragm needs adiitional gaskets/o-rings?
And what about my other questions?
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Mar 27, 2016 09:52 AM
