90 degree V-6? do they fit?
Old Dec 26, 2001 | 03:11 PM
1991v6camarors's Avatar
I know that the 1990-1992 Camaros use a 3.1 liter 60 degree V-6, I was wondering if a 90 degree would fit considering they can fit a 90 degree V-8 in there, also does a turbo buick motor fit in there too?
Old Dec 26, 2001 | 04:41 PM
Camaro_hunter_d's Avatar
Yes they will.
Old Dec 26, 2001 | 06:23 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Short and to the point response there man!
Old Dec 26, 2001 | 07:54 PM
DeadHero8's Avatar
do they bolt right up? motor mouns and bellhousing bolts?
Old Dec 26, 2001 | 08:14 PM
no. they require the V8 motor mounts, and trans.
Old Dec 26, 2001 | 10:42 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
yeh, v8 = 90* block, and v6 that is 90* block, needs a bellhousing that will take a 90* block. think v8 700R4, or maybe a 2004R like the TTA's. Would work, and could probably get a v6 90* block cheaper than a v8, (minus boneyard 350's) the bad part is, it'd be nearly just as much work...especially if u wanted FI.
Old Dec 26, 2001 | 11:26 PM
Engine: 2.8, LS1
But, yes they will fit
Old Dec 27, 2001 | 02:12 AM
Yes They will fit. I hit the wrong quote button. I do not like this new set up. I was used to the old one...
Old Dec 27, 2001 | 06:23 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
If going v6, get the gtp motor, 240 hp, 280 tq
or atl east a 3800 series II motor'
200hp 230tq
Old Dec 27, 2001 | 11:06 AM
DeadHero8's Avatar
i thought that our bell housings had the same bolt pattern as a small block, wich is a 90* block right?
Old Dec 27, 2001 | 11:30 AM
Nope.
Drone358
Dec 10, 2015 08:16 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
tglennon11
Sep 23, 2015 05:30 PM
Formula_88AE
Sep 3, 2015 01:47 PM
