JET performance chip
Old Dec 13, 2016 | 11:29 AM
LGS_18's Avatar
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
I have a 92 Firebird with a 3.1 V6. Panning on getting a stage 1 JET performance chip. Anyone have any experience? Could you feel a difference or increase of power or gas milage?
Thanks!
Old Dec 13, 2016 | 11:33 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: JET performance chip
On my friends 3.1L camaro it did not do much if anything
Old Dec 13, 2016 | 11:43 AM
LGS_18's Avatar
Car: 1992 Firebird
Ok. I had a race recently and lost by half a car and didnt know if it would help make up for it. I was gonna do JET chip, cold air intake, tires, plugs and wires.
Old Dec 13, 2016 | 11:49 AM
midias's Avatar
No it will not. Your car makes about 140HP max. A CAI might add one or two but it will sound better. Plugs and wires are not going to give you over 140HP they will maybe get you back to 140 but not over. Decent tires might help but IIRC my friends 92 3.1L auto did not have any trouble launching.
You best best for spending is to give it a full tune up, plugs, wires, cap, rotor, air filter and clean out the throttlebody.
Old Dec 13, 2016 | 05:23 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
you can buy my car that has all that 3400 heads/cam chip and so forth. doesnt cuyrrently run because im pretty sure i screwed the timing but i want it gone
Old Dec 13, 2016 | 09:07 PM
LGS_18's Avatar
Car: 1992 Firebird
I greatly appreciate your offer bro but i use my car as a daily and race everyonce in a while. Kinda just looking for a little bit more pep in my car. Thanks though!!
Old Dec 14, 2016 | 05:33 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
no worries, im trying to get rid of it and it sounds like it has all the stuff you want lol.
Old Dec 14, 2016 | 07:42 AM
midias's Avatar
Read this
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
And this
https://www.thirdgen.org/forums/v6/5...ost-power.html
When done do it again. Tons of good information
Old Dec 19, 2016 | 09:45 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
The chip won't do much. Thelse engines are hard to squeeze hp out of. Cam p and p the heads. Custom tuning, Headers. Nitrous turbo or hybrid swap. Those things will make a noticeable and sometimes major difference
Things like a Cai or wai, cat back exhaust, plugs wires, underdrive pulleys, mail order chips, won't do much of anything at all.
Old Dec 20, 2016 | 02:55 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Just study up on what "fasteddi" has done with his car. His v6 car is a rocket.
Old Dec 20, 2016 | 09:10 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Thanks man. Means alot.
Old Dec 23, 2016 | 07:04 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Even if you stay N/A, a catback with headers will do some good. A big bottle neck is that intake manifold too. Porting that woke mine up above 4500 RPM.
As everyone else has stated already, do the maintenance stuff first. You can't build upon anything if you have a crappy baseline to start with. I had gone quite a ways with mine N/A, wish I hadn't pulled it for a V8........
Old Jan 16, 2017 | 10:55 PM
Wafflestomp's Avatar
Car: 1987 Camaro, 1984 Camaro Berlinetta
Engine: cammed 2.8, turbo 3.1 hybrid
Axle/Gears: 3.42 one tire fire
If its in your budget def look into a hybrid swap with a turbo its what fasteddie runs and what im in the process of building if not in your budget then look at cam headers and porting a 260 grind cam is a good place to start anything larger then you will need to tune your ecm which shouldnt be to hard because u have a map car.
