1986 camaro V-6, 2.8 . Electric fan runs all the time and does not cycle. Check engin
Old Nov 9, 2017 | 09:59 AM
bikermark49's Avatar
1986 Camaro V-6, 2.8 mpfi . Electric fan energized when cold and stays on. Does not cycle on/off. When restarted warm fan does not energize when hot.
What's happening here?
Old Nov 9, 2017 | 11:38 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1986 camaro V-6, 2.8 . Electric fan runs all the time and does not cycle. Check e
You can diagnose with this schematic. Sounds like a faulty ecm.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Nov 9, 2017 | 11:52 AM
Engine: Lb9
Transmission: M20
The schematic doesn’t show it . The fan might have a switch in your cylinder head.
When grounded the fan turns on. What codes are you getting 15 ?
No need to start two posts on the same topic.
Old Nov 9, 2017 | 12:06 PM
Engine: Lb9
Transmission: M20
If your not familiar with retrieving the engine codes read this.
http://www.troublecodes.net/gm/
slow305
Jan 14, 2026 05:31 PM
Dale
Exterior Parts for Sale
62
May 29, 2018 08:10 PM
Nightwolf769
Nov 3, 2017 08:46 AM
ambainb
Oct 25, 2017 10:57 PM
