water pump bypass hose
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Does anyone know what the I/D of the water pump bypass hose is on our 3.1l? It runs from the water pump to the heater control valve, about 4 inches long and straight.
Thanks!
Thanks!
Car: 1998 Camaro Z28
Engine: 6.0L
Re: water pump bypass hose
It should either be 5/8 or 3/4. Cheap enough to just buy a foot of each and then you're covered.
Engine: 5.0l TBI
Thanks drdave88, I knew it would be a cheap simple fix, this Camaro usually is. It's just been too cold and snowy here to get under the hood.
Transmission: 5-speed/T-5
That would just be a heater hose...
The bypass on the 1st gen blocks is a port in the front cover that mates up to a hole in the block. It's near the lower rad hose connection.
WheelsUp84z
May 7, 2007 11:27 AM
TomP
Jul 28, 2002 10:12 PM
