89 RS 2.8L *Manual tranny* air pump delete help!!
Old Apr 25, 2018 | 12:38 AM
krismarsel1's Avatar
Engine: 2.8
What are the steps of getting rid of the AIR pump on a manual 2.8 v6. I wonder if it is tricky because standards come with the deceleration valve that is hooked up to the throttle body. Any help would be appreciated.
Old Apr 25, 2018 | 02:14 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: 89 RS 2.8L *Manual tranny* air pump delete help!!
Hi, took mine out, ordered shorter belt. Have to look at the exhaust manifolds where the air goes too, they will need welding up or blocking off , basically take anything off and back track anything that was connected to it lol block it all off.
i have no egr, air pump, air con, Dec valve, charcoal canister, cat, can't think of anything else right now ! Just tried to get the engine to be an engine !
Old Apr 25, 2018 | 05:39 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I took mine off too, it had no impact on the decel valve.
Old Apr 25, 2018 | 06:02 PM
Engine: 2.8
Correct me if im wrong, but the air pump has a vacuum hose that goes to the decel valve
What did you do to get around that
Old Apr 26, 2018 | 12:01 AM
Engine: 2.8
is it a big job? How many hours
Old Apr 26, 2018 | 12:02 AM
Engine: 2.8
Old Apr 26, 2018 | 01:13 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Not long with a basic tool kit , socket set , like I say just kept taking stuff off and backtracking it all to get pipes as small as poss then blocking them all off . Egr needs a blanking plate putting on on the intake manifold.and exhaust of you take all that off , spare bit of sheet metal , an angle grinder and a drill can whip them bits up quick .
noboostnogo
Sep 8, 2009 05:15 PM
Camaro Z Man
Aug 19, 2009 11:59 AM
xcel92
May 1, 2009 09:03 AM
TBITrucker
Aug 18, 2005 03:07 PM
I-Roc with my Z
Jan 21, 2005 03:34 PM
