Question about EGR
Old Jan 6, 2002 | 12:45 AM
1slowRS's Avatar
Question about EGR
I was changing the plug wire behind the altenator and accidently broke the hose on the EGR facing the altenator.My question is how important is it and can I tape it up for a day? Also will it throw any codes?
Old Jan 6, 2002 | 01:55 PM
NJ SPEEDER's Avatar
if it leaks any vacuum when it triess to open the egr you will get a code(i think it says egr non-response) it won't really bother the actual driving of the car too much. tape shoudl be able to hold it over until you get a new line on it. also, you can use any old poiece of vacuum line, it is not necessary to find the little piece of hard line like they used from the factory.
later
tim
Old Jan 7, 2002 | 03:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Agreed; a little piece of "real" vacuum hose can join two plastic hoses together pretty damn well. In fact, you could always replace the plastic lines with rubber all the way around. In fact #2, places like Pep Boys sell little coils of plastic "emissions tubing" (vacuum line), if you want to stick with plastic.
Old Jan 8, 2002 | 03:35 AM
1slowRS's Avatar
Thanks for the help, I guess I will replace all of them,they all have cracks and look like they have never been changed. Quick question I was following the one line and its goes under the cannister on the drivers side,what is that round ball under there?
Old Jan 8, 2002 | 03:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's your vaccuum tank; it "holds" reserve vacuum. Non cruise controlled cars have the tank on the firewall, below the driver's side winshield wiper; and it looks like a little rectangle.
Old Jan 8, 2002 | 04:16 PM
BitchinRS's Avatar
Tom,
Huumm Mines not cruise controlled and I have same ball in the same spot. I wonder if the car had cruise controll at one time.
Old Jan 9, 2002 | 02:10 AM
1slowRS's Avatar
Mine does not have cruise control either.
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
