TV cable, what the???
Old Jan 8, 2002 | 09:33 PM
BitchinCamaro13's Avatar
What is a TV cable and how do you adjust it? My car is shifting wrong and I was told it could be that.
Old Jan 8, 2002 | 09:53 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
I have absoulutely no idea. I got under there, located everything, and even after reading how to do it, was completely lost
Old Jan 9, 2002 | 01:22 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
The Throttle Valve is a valve in a non-computer controlled transmission.
In order for the transmission to shift properly, it has to know what the engine is doing. Here's where the cable comes into play. The cable is located on the Throttle Body. When you press the gas,the throttle plate opens and the cable pulls on a valve inside the transmission and essentially lets the tranny know what speed the engine is at in order to shift at the proper shift points. If the cable is streched or needs adjustment, the car won't shift right.
Here is the link to the tech article for adjusting theTV cable: https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Jan 9, 2002 | 01:13 PM
well, what happend was I replaced the 2.8 with a 3.4 block, changing all parts over from the 2.8. After I posted this message i looked around and found out what it was and how to fix the TV cable. Are you sure it is for all non-computer controlled cars? I was able to locate everything they were talking about.
Old Jan 9, 2002 | 08:58 PM
Engine: LH0 3.1L
I didn't say non-computer controlled cars......I said non-computer controlled transmissions(All thirdgens have non-computer controlled transmissions).
A computer controlled transmission will usually have a solenoid that controls shift points thus eliminating the TV and TV cable.
Old Jan 10, 2002 | 09:14 AM
Oh, sorry. Well, when "adjusting" it I didn't hear any clicks so I dont think that was the prob.
Old Jan 10, 2002 | 09:39 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
My 89 Vette had the same problem. I had to adjusted the TV cable about 10 times to shift how I wanted it too. I did not hear any clicks but felt the clicks.
Old Jan 10, 2002 | 10:15 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Btchin, you should've heard clicks as the cable pulled out of the adjuster. The cable should only be sticking about 1/4-1/2" out of the adjuster in the front.
Old Jan 11, 2002 | 07:46 AM
Well, I didn't feel or hear any clicks. I tried it again and still doesn't shift right. I don't think it is the TV cable. Any ideas what it could be?
thanks
Old Jan 11, 2002 | 09:42 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Can you take a picture and post here?
Old Jan 11, 2002 | 10:45 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
So; how far does the cable stick out of the adjuster? Is it coming all the way forward?
Old Jan 21, 2002 | 07:52 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I finally got to do that adjustment to my 85 and it ran perfect.YYYYYEEEEEAAAAAAAHHHHH, I drove it 30 Miles away to the shop I'm going to paint it in and the car.I'm so happy I'm now able to break my motor in without destroying my tranny.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
