New cat without smog pump?
Old Dec 15, 2019 | 01:58 PM
Iroc95's Avatar
Car: Camaro rs 1991, BMW e39, F11
Engine: V6 3.1
Transmission: 5 speed manual
Axle/Gears: Stock
Hi,
as restoration of my third gen is slowly moving towards the end I need to buy new cat.
My question is if I buy new cat that doesnt have smog pump air inlet hole can I run it without smog pump? Or do I need to get cat with smog pump air inlet?
Also how is with the emissions?
Thank you for help
Old Dec 15, 2019 | 03:15 PM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: New cat without smog pump?
Just get a cat with the inlet.
The smog pump pushes fresh air to the cat to make it more efficient.
Old Dec 15, 2019 | 03:41 PM
NoEmissions84TA's Avatar
GM actually admitted years later that the air pump was needed to dilute the exhaust to meet emissions standards at the time.
I don't know if your car came with a pellet type of cat converter or the better honeycomb type. You want a high flow honeycomb type.
Depending whether or not you have to pass emissions where you are located, and to what degree of restoration you are going for, if it were me, personally I would get the cat without the air tube and ditch the entire air pump.
Old Dec 20, 2019 | 02:02 PM
Iroc95's Avatar
Engine: V6 3.1
Axle/Gears: Stock
Thank you both, I will go with cat with inlet, just to be sure I will pass emissions test.
rover420
Dec 3, 2006 10:37 PM
johnjm22
May 1, 2004 12:24 AM
troobie
Mar 22, 2004 04:24 PM
350 TPI
Feb 22, 2003 12:00 PM
TransAm12sec
Oct 8, 2002 05:30 AM
