1991 3.1 engine issues
Old Dec 31, 2019 | 04:57 AM
Vincent Brier's Avatar
So my 1991 Firebird is having issues at times for some reason when I put the key in and start it it’ll crank turn over and then die and then when I take the key out let it sit for less than a minute open my door and wait for the sound And then crank it it turns over. I do have an aftermarket intake but I put back the stock air intake that was on it and the problem still occurs also I do have a rough idle at certain times and it’s feeling a bit luggage I thought it was the distributor cap at first to do with the power issue but I feel like it has something to do with my Ignition All the timing and everything seems to be fine it is spraying gas like it supposed to and I do have spark and good compression I’m not really sure please help
IROCThe5.7L
May 25, 2023 04:26 PM
M3638
Jul 13, 2014 04:21 PM
JohnTheBull
Feb 14, 2007 12:14 PM
sorch60
Jul 26, 2004 10:48 AM
mm68
Jul 30, 2003 04:34 PM
