Need some help with my 2.8 mfi
Old Jun 5, 2020 | 03:06 PM
Sstessman's Avatar
Car: 1985 chevy camaro
Engine: 400 sbc
Transmission: th350
Okay 1985 chevy berlinetta 2.8 mfi camaro i have replaced a lot engine wise to get it running smooth finally got it there but im getting smoke right where the crankshaft is when running i know my rod bearing need to be replaced and i have those on the way and when i have driven the car i can only get to 30mph but im not getting high revs that would point to the transmission being bad so i have a feeling my rod bearing could be causing tbis any other input would be appreciated and if you need more details id be happy to give it
Old Jul 11, 2020 | 11:20 PM
StevenJCH's Avatar
Car: 87 Firebird
Engine: 2.8l 60° V6
Re: Need some help with my 2.8 mfi
Had a similar-ish thing happen awhile back, Mine was in a sort of "limp home" mode. (Engine was healthy though). I disconnected the battery let it sit for 2 days reconnected it and she went back to normal, No more limitations at 30mph.
Hope this helps.
Old Jul 12, 2020 | 12:03 AM
Sstessman's Avatar
Engine: 400 sbc
Transmission: th350
Hope this helps.
thank you for the input I've tried resetting it in case of limp mode but still only going 30 i havent had the chance to replace the rod bearings I asked a buddy who had the same issue he had the smoking coming from the same spot as me he replaced his rod bearings didnt get rid of the knock and decided to put a 350sbc in his never found out what caused it that's why I'm asking for help I've changed plugs, wires water pump/ gasket alternator all belts cleaned my intake changed the thermostat and housing the temp sensor oil fuel pump fuel filter part of me Hope's for the rod bearings but I also have a feeling the injectors might be causing it not sure any other ideas?
Old Jul 12, 2020 | 12:15 AM
StevenJCH's Avatar
Car: 87 Firebird
Engine: 2.8l 60° V6
Do you have a 700r4 tranny? I'm not an expert on TV cables AT ALL, but a guy here at roebling raceway awhile back was having mph limitation issues (Didn't want to go above 45) and the TV cable needed serious adjustment. If it's not an automatic I'm leaning more towards a fuel issue aswell. Try some seafoam before tearing into it possibly? I will say getting to the fuel injectors on these engines is super easy compared to my old audi.
Old Jul 12, 2020 | 01:00 AM
Sstessman's Avatar
Engine: 400 sbc
Transmission: th350
I do have a 700r4 tranny had a feeling the transmission could be the problem as well but I certainly was hoping it wouldnt be will check out how sea foam works out then I'll start at the transmission any ideas for the smoking at the crankshaft?
Old Jul 20, 2020 | 03:28 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Your problem is that it's an 85 with the weak 2.8 crank and weak 700r4 . Dont waste anymore time and money on that unit. Swap it out.
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Old Jul 20, 2020 | 03:54 AM
Sstessman's Avatar
Engine: 400 sbc
Transmission: th350
I would agree but mine isnt the stock 85 2.8 it's a 90's swap from an s10 as for the transmission none of the gears are shaved actually just got back from a trip a few days ago and found my tv cable was the cause of it only going 30 and awesomely the clip to hold it onto the throttle broken in half and way too much slack about 1in - 1.5in of slack as for the crank I know the block was made in the 90's and since it's a 2.8 I wouldnt say its impossible for it to have those junk 84 and older cranks actually going to buy a 350 today so soon my 2.8 worries will be turned into a coffee table with a long story lol thank you for all the ideas every I appreciate the feedback I got a plethora of new 2.8 parts any ideas where I should post them? (Besides craigslist and facebook)
grovestreet
May 25, 2008 06:18 PM
autoholic
Jan 27, 2008 03:55 PM
fearfactory17
May 2, 2006 02:08 PM
Xceleratemaro
May 4, 2003 04:02 PM
Crazy2.8V6Man
Jun 28, 2002 05:44 PM
