Fuel Injectors
Old Apr 7, 2022 | 07:09 AM
1990Camarorss's Avatar
Fuel Injectors
This is probably a dumb question but, I've been trying to get my Camaro running again but two of my injectors were bad the only spares I have were 16 ohm while the rest are 12 ohm. Is this gonna affect anything if I have two 16 ohm and four 12 ohm?
Old Apr 18, 2022 | 08:28 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Fuel Injectors
I think sec is 16 ohms. O the 12 would probably be bad
Old Apr 21, 2022 | 01:21 PM
southbay08's Avatar
Re: Fuel Injectors
you need a new set of injectors
Old Apr 24, 2022 | 01:12 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Fuel Injectors
You may need new injectors but... Have you checked the fuel pressure? I was about to pull my injectors because the car has hardly been run for a few rears and I replaced the pump recently. However, I checked the pressure and it's zero so injectors stay put for now. 12 ohms is a little low but may be ok. My "bad" ones were around 3 to 5. I've got the Southbay injectors and they've been great.
webeeZ28
Sep 14, 2015 12:00 PM
ace322
Nov 18, 2013 07:37 PM
89IROCK
May 1, 2009 02:54 PM
jcp74
Apr 29, 2008 11:36 PM
spedrace35
Dec 9, 2005 06:58 PM
