Code 33
Old Apr 26, 2022 | 10:44 AM
1990Camarorss's Avatar
Code 33
Could a leaking intake manifold gasket cause a code 33? I feel like it's a vaccum leak because the car can't find idle after coming down from throttle while driving and it tries to die when you give it a little gas and idles fine in Park so I'm just confused
Old Apr 26, 2022 | 11:09 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Code 33
https://www.thirdgen.org/forums/tpi/...ll-1991-a.html
3.1l ?
Old Apr 26, 2022 | 11:21 AM
Re: Code 33
Yes, 3.1l. I've already replaced the map and backprobed the wires to check it as well
Old Apr 26, 2022 | 11:45 AM
Engine: Lb9
Transmission: M20
Re: Code 33
I’d start looking for leaks with carb choke cleaner but have a fire extinguisher handy just in case. Iirc lots of hoses coming off throttle body connector on the 3.1
Old Apr 26, 2022 | 12:39 PM
Re: Code 33
The only leaks I found doing that were around the egr tube but I fixed them and it still does the same thing
rumpilstiltskin
Apr 26, 2022 07:15 PM
asaman97
Apr 25, 2015 07:00 PM
Gutz
Apr 4, 2009 07:04 PM
tchernobog
Jan 14, 2009 03:20 PM
FAST RS
Feb 6, 2007 03:08 PM
