Do I need to wait for security light to go off?
Old Sep 22, 2022 | 05:45 AM
Iroc95's Avatar
Car: Camaro rs 1991, BMW e39, F11
Engine: V6 3.1
Transmission: 5 speed manual
Axle/Gears: Stock
Hy,
I rebuit my 3.1 fully, I didn't touch wiring in the dash yet.
It happend 2 times now that when I would turn the key car woudn't crank ... had tryed depressing clutch pedal and it does nothing.
When this happens I need to take the key out, insert it back and car would start and cut off and just crank after that. Then I need to take key out again and on next attempt car starts instantly.
New IAC and TPS, no vacuum leaks, new spark plugs and cables.
Thoughts?
Thank you
Old Sep 29, 2022 | 08:21 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Do I need to wait for security light to go off?
Normally with VATS you need t owait a good 15 min before you can try crank / start.
the security light will go out after a short time when you turn the ignition to on. if its workign ok... if not it would stay on
Old Sep 30, 2022 | 05:43 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
With a properly working VATS, (like on my 89 IROC Z Vert, with a new VATS Module and Ignition Lock Cylinder) you DO NOT have to wait for the "Security" light to go off, to start the engine.
Old Sep 30, 2022 | 04:17 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Whoops, realized I put it wrong
Normally with VATS "activated" or if it detects an error in the key or something..... you need to wait a good 15 min before you can try crank / start for it to reset
If its working fine and detects no error, the car will start right up and the security light will go on and off during start up.
Alaska Hwy 1Le
May 15, 2008 04:24 PM
ridin_low07
Mar 21, 2008 12:35 AM
RED92BIRD305
Feb 18, 2004 02:59 PM
1987gt
Nov 26, 2003 06:44 PM
MILT
May 18, 2001 06:02 PM
