Squealing Noise
Old Jan 10, 2023 | 04:04 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Squealing Noise
Anyone what this noise is? I’m not sure what exactly it is so I’m putting it in the V6 section.
It happens at ~25mph and above and sounds like it’s coming from the front right inside of the car, like behind the steering column. Doesn’t happen when it’s hot outside but does happen when it’s cold and/or wet. It doesn’t have to be very cold for it to happen. It squeaks more the faster the car is going and it happens less the more the car is driven in a day.
Video should be attached to this post with the noise when I’m on the highway.
Old Jan 10, 2023 | 04:11 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Squealing Noise
EDIT: video didn’t attach so here it is
File Type: mov
Old Jan 10, 2023 | 04:23 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Squealing Noise
Hi KITT87, That sounds very much like an air leak I had until I replaced my door seals. My car would make the exact same sound, only when wet and only when going above 60 or so MPH. I think the air was leaking at that big block of rubber at the top front of the door. I haven't heard it since I replaced the complete door seal set.
Old Jan 10, 2023 | 05:31 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Squealing Noise
Like these? I’ve replaced my window weatherstrips (same noise before and after)
but not the ones around the bottom of the door
Old Jan 10, 2023 | 05:36 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Squealing Noise
Yes, exactly those seals ( I used Classic Industries and they fit fine)
Old Jan 12, 2023 | 03:20 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Squealing Noise
Sweet! I got the OER weatherstrips from classic industries and was pretty disappointed with the fit and quality but I’m glad these ones are better. Looks like they’re “arriving soon” though so I might have to try to find them sold elsewhere if they’re not back in stock anytime soon. As usual, thanks for helping me with my greenhorn questions!
Old Jan 13, 2023 | 05:05 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Squealing Noise
Your welcome
Old Sep 3, 2023 | 08:14 PM
KITT87's Avatar
Engine: 2.8 V6
Re: Squealing Noise
Coming back to update in case someone finds this through the search: it was actually the seemingly infamous speedometer cable squeal. Greasing didn’t fix it and I wanted to replace the old two-piece style cable so new cable is on (pioneer, chose it since it’s longer) and the problem sound is gone.
Pms81
Sep 28, 2017 04:33 PM
thunder85
May 30, 2015 03:12 PM
