ram air on a camaro
Old Jan 22, 2002 | 08:06 AM
Bluerocket's Avatar
ram air on a camaro
I was wondering if any body hid pics of ram air for a camaro. I thinking of making ram air on my car useing the holes in the front facia
Old Jan 22, 2002 | 09:18 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
try this it's in the tech articles of www.thirdgen.org
Old Jan 22, 2002 | 11:39 AM
Camaro_hunter_d's Avatar
I posted a thread that was named "how's This for CAI" It had the beginnings of the system that I put togeather. However it does serve those that do not want to "Modify" the front fisca/nose of thier third gen Camaro to use it simply as a CAI. I turned it into a ram air by routing the tubing to the front of the car and cutting out the turn signals and mounting them in a solid filer panel that took the place of the grill. The typical way is using the TPI intakes and fabracating ducts that will grab air from where the Z Fog lights are mounted, but I think the the air has too many directions to go and this causes turbulence in the air flow(A Hinderance). The system I out togeather uses 3 inch PVC/ABS plastic tubing and it(The Air) only has 1 place to go and it not squeezed through the tight passages of the over the radiator intake.
Old Jan 23, 2002 | 01:59 AM
Alf's Avatar
Alf
Camaro_hunter_d,
Could you repost the pictures again, please?
I can't see them on Geocities...
Thanks,
Alf.
Old Jan 23, 2002 | 10:53 AM
here...
Old Jan 24, 2002 | 09:12 PM
Bluerocket's Avatar
Anybody have pics of car using ram air hood that works on a 2.8. I need a hood and a light fiberglass hood that has ram air will fix both problems
Old Jan 26, 2002 | 11:12 AM
90CamaroRSGuy16's Avatar
maybe I just don't get this.....
So if you're cutting off the stock intake, where do u put an air filter?? Thanks guys
Old Jan 26, 2002 | 12:50 PM
Depends on this intake your making. Onmine they are actually outside the car. I do plan on getting different air filters and having them mounting under the hood after I get the ABS remade into metal tubing. If you go with something like the pic I posted you will need 2 conacal air filters, or if you go 1 90* off the throttle body instead of the Y I used you need 1 conical.
Old Jan 26, 2002 | 12:56 PM
ok.....let me get this straight
ok......so if I use the pipes, but want to run it through the foglight holes, where do I attach the filter? A regular K&N filter wont work, will it? or will it fit inside of the a/c duct, or pipe?? Do I have to cut it??? thanks
Old Jan 26, 2002 | 01:04 PM
Re: ok.....let me get this straight
most people use enclosed gutter tubes to make the actual duct that goes to the factory airbox(those with the 5.7 TPI style anyway). There you have the K&N factory style filters.
Old Jan 26, 2002 | 05:00 PM
fatass's Avatar
Car: 1986 Sport Coupe
Engine: 2.8l V6
Transmission: 3 speed auto
here
http://www.thirdgenresource.com/index.html
scroll to the bottom
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
