What are idle RPMs for the 3.1 V6?
Old May 1, 2024 | 10:26 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Transmission: 5 speed
My 92 RS with 3.1 V6 idles around 1000-1100 RPMs when fully warmed up. Starts around 1800-2000 when cold. Isn't the idle RPM a bit high? It is a stick shift.
Old May 1, 2024 | 01:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What are idle RPMs for the 3.1 V6?
Is your tachometer correct ? Checked for vacuum leaks ?
Old May 6, 2024 | 02:03 AM
luca's Avatar
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
specs for a manual should be 800-900 operating temp cold start i think ~1500
Old May 6, 2024 | 08:35 AM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
Thanks. I may actually have a vacuum leak. Just need to find time to check it.
Old May 11, 2024 | 05:09 PM
drabina's Avatar
Car: 92 Camaro RS
Engine: V6 3.1
I connected my smoke pump to the hose by the brake booster. The only smoke that came out was by the air filter. Noting in between. The tach still shows about 1200 as the running (engine warmed up) RPMs. To my ear, the car does run at high RPMs so the tach could be correct but I am not an expert. Any other ideas?
Old May 13, 2024 | 01:51 AM
luca's Avatar
Car: Firebird
Engine: 3.1
check for a dirty iac valve maybe it cant seat annymore
91v6
Dec 20, 2023 09:32 AM
LarryD
Nov 11, 2021 11:51 AM
luca
Mar 23, 2020 01:33 PM
ozwin
Nov 26, 2019 12:02 PM
92camarorv6
Apr 9, 2012 07:11 AM
