battry ground cable question
Car: 1989 Firebird
Engine: 2.8l
So I've been having starting issues for a while in my 89 2.8. Decided to do some clean up in the engine today and verify all vac lines (work has been crazy so i havent had time to touch it) and i noticed that the battery ground is going to the fender instead of the block. What size and length of wire do I need to replace it?
Car: 1989 Firebird
Engine: 2.8l
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: battry ground cable question
IIRC you should have two cables coming off the negative terminal a smaller one that may go to the fender and a larger one that goes to the motor
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
It's supposed to go to a cylinder head or block. There might be a small pigtail going to the fender apron, but that is not the main connection point...
Car: 1989 Firebird
Engine: 2.8l
yeah, the previous owner put it under the washer reservoir and I just saw it. That is probably why it's had hard starting issues since I got it. it's most definitely the 4 gauge on the fender. it should connect to the block, right behind the AC Compressor right?
Car: 1989 Firebird
Engine: 2.8l
Trying to find one at a local part store atm. Happen to have a part numer or anything?
Shadow13
May 9, 2012 04:46 PM
