valve springs?
Old Jan 24, 2002 | 04:11 PM
Monkie's Avatar
valve springs?
Whats the numbers for a performance set for our cars? A number would be great and how much will they cost? Should I call Jeg's and ask or what? Thanks guys.
Old Jan 24, 2002 | 05:04 PM
Camaro_hunter_d's Avatar
When i get home from school tonight I will post some #'s for ya.
Old Jan 24, 2002 | 08:36 PM
Monkie's Avatar
ok thanks
Old Jan 24, 2002 | 08:48 PM
KED85's Avatar
Monkie,
When GM made the Baretta Pace car for the 1990 Indy, they used ISKY springs.
In the GM Performance Parts Book, they use Crane springs.
WHAT IT COMES DOWN TO is several things.
Open pressure is 80-100 closed is close to 200+.
All they really are is "generic" Z-28 Springs, meaning open is 80-100 lbs, closed is closer to 200 lbs.
NOW you CAN reshim your old springs to make these pressure readings.
THE BEST SUGGESTION is ALL NEW VALVE GUIDES and then re-shim springs for the proper spring pressure.
I hope is well for you, friend! Take care.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
