Power steering pump pully replacement
Old Aug 30, 2025 | 11:04 PM
syndealer's Avatar
Car: Camaro RS
Engine: 3.1 V6
Transmission: Auto 700r
I have a 91 v6 RS and while changing out a bad water pump, I had to remove power steering pully. The lip on the pully broke while removing. I cant seem to find a replacement that fits a serpentine belt that can be confirmed OEM replacement. Anyone else come across this issue? Or have a suggestion.
Thanks in advance
Old Aug 31, 2025 | 08:57 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
Re: Power steering pump pully replacement
Are you sure the power steering pump has a serpentine belt?
My 1986 V6 has a serpentine belt on the water pump but a Vee belt on the power steering.
I'm guessing you need a water pump pulley that has both the serpentine belt and Vee groove pulleys.
I did a quick online search and didn't find one of these pulleys new, so you may have to visit your local auto wrecker.
Old Aug 31, 2025 | 10:07 AM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Know of that issue all too well!
Best advice is to use an impact on the puller - lessons learnt.
chris
Old Sep 1, 2025 | 03:03 PM
syndealer's Avatar
Car: Camaro RS
Engine: 3.1 V6
Ya im sure. After cleaning the build up off I found the PN# 14100597 but can only find used on ebay. I find it crazy that no one makes an aftermarket.
Old Sep 3, 2025 | 03:19 PM
OrangeBird's Avatar
Car: 1989 Firebird
Were you using this tool?
https://www.summitracing.com/parts/wmr-w87022
Old Sep 3, 2025 | 09:48 PM
syndealer's Avatar
Car: Camaro RS
Engine: 3.1 V6
Yup, similar rental from o'reilys
Old Sep 4, 2025 | 10:01 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
He has a '91, so it would definitely be a serpentine belt. I was in the local yard the other day and came across an '87 with a full serpentine 2.8L as well, and recall an '88 at that yard years ago with the same. I don't know for sure, but '86 seems to be the last year that V-Belts were used on the V6
82z28power
Nov 14, 2014 02:52 PM
85Iroc-Z
May 23, 2014 06:54 AM
Paddiee
Oct 15, 2010 01:42 AM
afida15
Fabrication
Feb 21, 2008 11:17 AM
94-6spd
Apr 4, 2003 06:01 PM
