2.8 Help Needed
Old Nov 26, 2025 | 05:08 PM
@Frustrated1's Avatar
2.8 Help Needed
OK, I'm pulling out what little hair I have left over this. 1985 2.8L multiport injection. My mass air flow meter signal voltage will not change when running, and it stays in open loop. With the sensor unplugged I have the 5 volt signal, but as soon as I plug it in it drops to 2.5v. I've tried one rebuilt and 2 brand new MAF sensors. I've checked and cleaned all grounds, battery to engine, engine to body, body to battery, and MAF sensor ground to body. Also have cleaned and checked connection at ECM, ran a bypass wire from sensor to ECM, and have even put in a rebuilt ECM. There is something obvious I'm missing, what the heck is it?
Old Dec 15, 2025 | 05:21 PM
82-T/A [Work]'s Avatar
Re: 2.8 Help Needed
Is your O2 sensor properly hooked up, and does the car properly warm up?
@Frustrated1
Nov 26, 2025 05:06 PM
zmasta101
May 29, 2008 12:45 PM
87IROCZ53
Aug 30, 2007 08:54 PM
ZheKo
Mar 28, 2003 06:29 PM
tpi cj
Mar 18, 2002 09:11 AM
