Zero Drag Drums
Old Jan 28, 2002 | 04:10 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
Zero Drag Drums
how can i adjust my rear Drums for Zero Drag so i wont wear them out when i power brake?
1991 3.1 RS SC
Old Jan 28, 2002 | 05:13 PM
AntiVTEC's Avatar
You can adjust the drums with a tool that slips into the slot on the inner side of the drum. But they'll just go right back to where they were since they are auto adjusting. What you really want is to get a line lock setup for your car if you really intend to do power brakes all the time.
Old Jan 28, 2002 | 09:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
The drums will self adjust when you drive in reverse & apply the brakes, otherwise this is a good trick for the track.
Old Jan 28, 2002 | 11:41 PM
Ovrclck350's Avatar
Hell no it's not. think about it, at the end of the 1/4 mile, what do you do? You brake...at high speeds...quickly. How is having no pressure applied to the rear a "good" tip for the track?
Old Jan 29, 2002 | 07:23 AM
Engine: 5.7 / 7.4
you have 70-80% braking force on the front discs. thats why rear shoes last so much longer than front discs.
new graemlems again
Old Jan 29, 2002 | 09:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Rear drum shoes are what, $14? Why care about wearing them out? This reminds me of "if I race my car, will I break the engine?" I'm not trying to be harsh, but think about it- Anything we do out of normal driving is hard on the drivetrain; when your rear shoes get worn down, replace 'em! There's a picture-by-picture procedure in the Haynes 82-92 Camaro (or 82-92 Firebird) book.
Old Jan 29, 2002 | 10:35 AM
Engine: 5.7 / 7.4
an "off highway"alternative would be to just removes the rear shoes.
very "off highway"
Old Jan 29, 2002 | 11:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, is that possible? Wouldn't you have to remove all the springs and everything, too? Also, wouldn't the wheel cylinder's piston shoot out the side? I don't think there's any provision to keep the wheel cylinder's piston inside the wheel cylinder; the thing might overextend itself.
Hey, wait... couldn't you use a hose crimper on the rear axle-to-body hose instead? You know those things; they look like little vise-grips, and crimp hoses shut (like fuel lines).
Old Jan 29, 2002 | 01:04 PM
Engine: 5.7 / 7.4
a home made c-clamp. pistons shooting out, as sonn as I started reading TomPs post I was like "oh yeah " Ya still have front breaks though
Old Jan 29, 2002 | 02:04 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
so what shold i do then ?
should i just pwr brake like it already is ?
it doesnt hurt the rear drum brakes too much does it?
i mean other then wearing them out ? i don t wanna mess up nunna them components in the brake system...
so its true U can actually set them to zero drag then?
and U say it resets only when i throw it into reverse?
Old Jan 29, 2002 | 02:24 PM
Engine: 5.7 / 7.4
yes & yes
Old Jan 29, 2002 | 02:28 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
thanx guys
:lala: :lala: :lala: :lala::lala: :lala: :lala: :lala: :lala:
:lala:
Old Jan 29, 2002 | 02:47 PM
Ovrclck350's Avatar
I still think it's a bad idea.
Old Jan 29, 2002 | 09:52 PM
I Cant Drive 55's Avatar
Its true 70 to 80 percent of your braking is from the front brakes .
However,your brakes are designed so that the rear brakes take up first, before the front brakes. Adjusting to zero drag will cause you to lose alot of your pedal. Bad Idea.
A line lock makes more sense to me if power braking is what you want.
Old Jan 30, 2002 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd love to get a line lock.. that'd be bitchin' at the track...
1. MSD 6AL box
2. 2-stage RPM limiter
3. Linelock
Pull up to the line, engage the first limiter, engage the linelock, and mash the go-pedal to the floor. When the light goes green, hit a pushbutton mounted to a spiral cord- your 2nd limiter (redline) kicks in, linelock shuts off, and you've got one HELL of a reaction time!
Problem is; how safe is a linelock for the street? How do they react to heat & weather & other situations that street cars see that race cars don't?
Old Jan 30, 2002 | 01:13 PM
grimesjm1's Avatar
Actually guys, there is actually a Technical Safety Bulletin (TSB) on the automatic camaros and a recall on the manual camaros about the rear brakes. If I remember correctly it has something to do with the self adjuster malfunctioning. It's actually an emergency brake tsb/recall, but it is because the rear brakes malfunction, and that's what the e-brake uses to hold the car. GM admits there is problem, but won't foot the bill for the auto, only the manual because it is needed more. Nice, huh?
BTW, You can't just take off the rear pads, because you're braking system isan entire system, not front/bak seperate, when you lose fluid from the rear, it will affect the front, no matter what that little regulator is supposed to do. Pinching off the line is the only real way to remove the rear brakes. I agree wit Ovrclck350 though, not a good idea.
Old Jan 30, 2002 | 04:12 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
any ideas on where to get a line lock?
possibly without having to go online?
if its in Jegs SUmmit or JC whitney lemme know ok?
and is the line lock expensive at all?
and if i ever get one could a average guy like me install it in the car?:lala: :lala: :lala: :lala: :lala: :lala: :lala: :lala:
Old Jan 31, 2002 | 01:41 AM
Ovrclck350's Avatar
They're like $30, easy to install, and a lot safer than "zero drag drums"
Old Jan 31, 2002 | 10:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
grimesjim1, I've only heard of that recall/TSB info for f-bodies with rear discs only, not rear drums. In fact, look for my message about a "hard pedal"- I put the recall kit into my calipers. Search for messages by me on the Suspension/Drivetrain board; I got the recall kit for under $50 from http://www.gmpartsdirect.com . Individually, the TSB parts were well over $200! (The recall kit # is the one GM doesn't want us to know.)
Old Jan 31, 2002 | 10:59 AM
grimesjm1's Avatar
TomP...ok thanks. I didn't remember tht...I just rember readin something about it somewhere, don't even remeber where. I have no e-brake b/c evrytime I adjust my rear pads they hold for like 2 days then I lose it again. But thanks for the info....
Old Jan 31, 2002 | 11:43 AM
KED85's Avatar
Is that why my E Brake arm pulls up so high?
I've got an '85
Line locks.
Work real good for an antitheft item, too!!
All you are really doing it adding a solenoid into the brake system.
Look at your brake system at the firewall.
That's where you add it.
Do you want to mess with that?
Can you mess with that?
Got the proper tools?
Look at www.MrGasket.com for the Hurst Line Lock.
Old Jan 31, 2002 | 03:02 PM
BitchinRS's Avatar
Recalls and TSB's
If you want to get a list of recall and TSB's here is a site you that has them. The list is free, but if you want the reacall notice or TSB they want $24.95 year for online access.
If you were to give a dealership the document number would they be able to give you the particular recall notice or TSB?
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
92projectcamaro
Dec 8, 2015 12:25 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Prodigious
Sep 18, 2015 05:23 AM
