New coil for my 2.8
Old Feb 15, 2002 | 02:57 AM
86camarodriver's Avatar
New coil for my 2.8
Last summer I rebuilt my ignition autolite plugs auto zone type wires, blue streak cap and rotar. With all this I noticed A LOT better gas mileage and better performance. The coil is still stock and looking very old, its the same one that came on the car from the factory in 1986... If I drop an MSD coil in will this help performace or just make the engine run smother, I wanted to get a higher voltage coil but I am afraid I will melt the wires.
Sugestions????
David
:hail: :lala:
Old Feb 15, 2002 | 11:23 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you will not melt wires, that's what headers are for. get a better ignition module to with the new coil to get the most out of it.
Old Feb 15, 2002 | 12:06 PM
WaynesRS's Avatar
:sillylol:
Old Feb 15, 2002 | 12:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When I didn't have an MSD ignition (6AL box & Blaster SS coil), I was running the Accel external HEI coil. I noticed a power improvement at higher rpm's, so it'll help a bit.
You can nab a set of Accel 8mm wires from http://www.northernautoparts.com (I think you have to call the phone # for the part #) for about $20. Aren't the Autolite wires 7.5 mm?
Old Feb 15, 2002 | 12:49 PM
WaynesRS's Avatar
I have accel wires (8mm) I really like them , they kick @ss !
Old Feb 15, 2002 | 05:40 PM
Keoki_Firebird89's Avatar
which is the accel thats good for v6s cuz when i went today the universal fits set v8s and stuff.
which accel would work cuz i wanna get them for my incoming 3.4L
must perfect my ignition.
Old Feb 15, 2002 | 06:22 PM
Engine: 5.7 / 7.4
universal sets are that, universal. Get the color you want, cut to lengnth, have 2 left over for spare.
Old Feb 15, 2002 | 06:35 PM
KED85's Avatar
On my set up, I use Accel everything.
Except I use a GM coil on distributor shaft & AC Delco modular.
I use Bosch Platinum (not the 4 tips)
I use Accel 8.8 plug wires
and a Accel coil for the proper bracket.
I choose to remote mount them. I have this one on a simple L bracket, suspended from the firewall overhang.
The car sings.
Definetly go for a new Accel coil, very nice surprise improvement.
It's subtle.
Old Feb 15, 2002 | 08:32 PM
Ked, how much is that coil???
Could I still mount it in the factory location
Im changing my fuel filter tomarrow.... hopefully I wont die LOL
:hail: KED85
David
Old Feb 15, 2002 | 09:06 PM
WaynesRS's Avatar
:hail: KED85
David
Please , DON'T forget to de-pressurize it !!!
Old Feb 15, 2002 | 09:08 PM
Explain please....
Old Feb 15, 2002 | 10:43 PM
BitchinRS's Avatar
Jack the rear off your car up and near the rear end is the power conection for the fuel pump. It will be the only wire conection in the area. Unplug it. Lower car and start or try to start engine. If it starts wait for it to die. When you are done changing the filter reconect the wire..
Old Feb 15, 2002 | 10:53 PM
yea I dont feel like being blasted with fuel LOL
thanks man
David
Old Feb 16, 2002 | 11:02 AM
KED85's Avatar
Kragen sold me mine for $36.
Get the part number (forget mine) shop around for the part.
Make sure they can get it, tho.
Sure you can mount the proper Accel coil in the stock spot.
I choose not to.
Lousy location.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
usafirebird
Sep 29, 2015 11:58 PM
