Smaller mods to a V6
Old Mar 3, 2002 | 03:46 AM
maverick544's Avatar
how much would a performance chain (It think a double roller one), 180thermo, CAI and rebuilt distributer cap with bosch sparkplugs add to a V6 2.8. And how hard is it to install one of those chains, if pretty hard how long on labor.
I think around 8-12hp if I'm lucky.
Old Mar 3, 2002 | 09:32 AM
V6camaroman's Avatar
maverick if your going to take the time to put a new double roller chain on you might as well throw a cam in too. if you want some more mod ideas look at my signature. oh by the way i see you live in rochester. is that rochester ny? if so i live about 50 miles south of you
Old Mar 3, 2002 | 10:29 AM
KED85's Avatar
Take advantage of knowledge & help
BUY HIM A CASE OF LIQUIDS!!
All you'll do is GAIN BACK power LOST over the miles.
How much will that gain be?
Depends.
Do a cmpression test, too!
See what's going on.
Old Mar 4, 2002 | 10:25 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Swapping the cam is quite a bit more involved than just doing a timing chain; yeah, it would make sense, but it's more work. He'd have to yank the top of the engine off to get at the lifters!
Cloyes is the only one that makes a true-dual-roller timing chain for our 2.8's. Summit carries it, I forget the part number (call and ask at 800-230-3030), and when I bought it, it was $90. A gasket kit cost me another $20.. it was a Felpro kit, and came with a new front seal. If you have no idea how to put it in, you need to buy the Haynes 82-92 Firebird (or Camaro) manual for $15.
Old Mar 4, 2002 | 01:47 PM
KED85's Avatar
Northern Auto Parts
$50-ish delivered.
New chain, water pump and gasket set.
All name brand stuff.
Could be Speed PRo chain.
Old Mar 4, 2002 | 04:21 PM
Camaro_hunter_d's Avatar
Originally posted by KED85
Northern Auto Parts
$50-ish delivered.
Hey KED does NAP have a number. I am thinking of doing the chain over spring break and maybe some other things too.. LIKE A CAM.
Old Mar 4, 2002 | 09:43 PM
KED85's Avatar
800-831-0884
Can't go wrong with stuff from these guys.
IF you are thinking about other gaskets (header?) buy em now & save on the shipping!
Forget the cam, get Roller TIP rockers, 1.6 ratio. That'll wake up the factory cam cheap & easy!
Old Mar 5, 2002 | 10:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
One problem, though, with "waking up" the factory cam- what if the lobes are ground down to crap? When this 2.8 gets rebuilt (or, more accurately, when I rebuild a junkyard 2.8), I intend to check the gross lift of each rocker arm... I bet those suckers are ground down by now. I'd probably even get some power if I put a new factory-grind cam in my 230,000 mile 2.8!
'Course I guess my mileage is an exception around here
Old Mar 5, 2002 | 10:38 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Camaro_Hunter_ D,
You can also check out there web site at http://www.northernautoparts.com/ and order a free catalog from there. I got my rebuild kit and crank from them a few years back and it was all quailty stuff. I was very pleased especially with the price.
On a side note, (going by your name) have you seen the new Vampire Hunter D video yet?
Old Mar 5, 2002 | 11:56 AM
Brian K's Avatar
I have the coyles double roller.. It fells like it slowed my car down, but I know it didn’t.. It just feels so darn different than the old stock one was. It is supposed to give you 1-8HP they claim.. I know my car runs smoother and it should have been done years ago.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
bschmale66853
Sep 30, 2015 08:11 PM
