Brake lines / bolt size.
Old Mar 5, 2002 | 01:18 PM
BitchinRS's Avatar
Hopefully I will be doing my brake lines and wheel cyliander this weekend. What I need to know is what size flare nut wrenches do I need to change the brake lines?
I don't have much money right now and don't want to spend a crap load of money by buying an entire set of flare nut wrneches.
Old Mar 5, 2002 | 02:34 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Well if you don't want to spend any money on flare nut wrenches. Go to a local Garage, and borrow one. It will be cheaper. They might ask for a deposit that you will get back when done with it. But atleast you will save yourself some money.
Old Mar 5, 2002 | 02:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
not sure on size, but will either be SAE or Metric. my front are metric.
Old Mar 5, 2002 | 05:44 PM
BitchinRS's Avatar
Thanks for the replys.
My brother has some flare nut wrenches, but I'm not sure if he has the right size. That's how I was planing on saving money. May just have to brake down and buy a set.
Old Mar 6, 2002 | 12:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I posted a reply on the chassis/suspension board, but I'm pretty sure the lines are 11mm. We have an 11mm/12mm combo flare nut wrench from Home Depot, and one of those definately fits the lines. See my tip over at the chassis/suspension board about how I freed lines that wouldn't move. Oh hell, I'll quote it here:
Originally posted by TomP
I believe they are 11mm.
If you've got a stubborn one, try what I did. My flare nut wrench was actually rounding out one of the line nuts, the nut was on so tight. So I broke out the huge SOB adjustable wrench... the 12 incher. I tightened it down on the line nut, and gave the wrench some quick & hard "pushes"- and the nut broke free. Just something to try!
Old Mar 6, 2002 | 01:59 PM
BitchinRS's Avatar
Thanks Tom. I did a post on the brake board and hear, becuase I some times don't get a respones from the other board. But this was exactly what I was looking for. The nice thing is that my brother has the right size wrenches so I don't have to go out and buy any. Unfortunetly I may not be able to go with the steal braided lines like I wanted to due to money constraints, but at least I will be able to fix the problem and get my braking ablity back!!!
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
