ideling questions need help
Old Mar 8, 2002 | 11:22 PM
86BIRD-MY FIRST CAR's Avatar
1. What RPM Should a typical 2.8 idel at during rest/in park.
2. what does it mean if my RPM needle jumps between 500 and 1000 RPM at rest/in park
3. and when i step on the gas car is not quick to respond does it have to do with the ideling?
Thanks------Abe
Old Mar 9, 2002 | 12:49 PM
Come on guys im painted in a corner here........
Old Mar 9, 2002 | 12:50 PM
And the lucky person to answear my post is........
Old Mar 9, 2002 | 01:48 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Sorry I don't have an answer but a lot of people on this board have the same idling problem. Mine when it's idling regular is at 800 rpms. But it's a five speed. Sorry I couldn't help though.
Old Mar 9, 2002 | 01:54 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Check for vacuum leaks.
Old Mar 9, 2002 | 05:19 PM
89camaroRSV6's Avatar
mine too idles at like 800rpm... but in park its 1000
in gear its like 800 i have an auto though...
like calicamaro said check the vacumm
Old Mar 10, 2002 | 03:23 PM
Ratchet's Avatar
It should be ideling at about 750
When My car was jumping around on the tack at idle and accelerating slow I discovered that the spark plug wires had gone bad and that the spark was jumping to ground causing the tac to bounce around.
Go Out tonight in the dark and open the hood see if there are sparks jumping around in there.
I'd say I'm about 80% confident that this is your problem.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
