Intake Air Temperature Sensor
Old Mar 30, 2002 | 10:37 PM
JoKEpLaYeR's Avatar
I'm working on a CAI so I pulled the plug on the intake air temperature sensor, I think... it's the one on the air canister. After the car warmed up, the check engine soon light popped on so I pulled over and plugged it back in and it ran fine... What do I do with this sensor when I setup the CAI? Does this sensor need to be grounded or anything? Should I just thread a whole in the new pipe I’m using and stick it in? Can I leave it outside the pipe and just attach it to the frame or something?
Thanks,
Steve
Old Mar 30, 2002 | 11:15 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
You need the Temp. sensor to stay inside the air tube someplace, if you put it in the engine compartment it will read wrong. If your Temp. Sensor is bad get a new one.
Old Apr 17, 2002 | 09:08 PM
ice775899's Avatar
you need to have it inside the tube or your car will run very bad.i tried the same thing and i just ended up putting it right in front of the tb and has never better.
Old Apr 18, 2002 | 07:39 AM
SAEspinz80's Avatar
yea, just get it inside the tub somewhere....this is under my 45* bend. i just made a whole with a paddle bit and it screwed right in.
SAEspinz80's Avatar
wide
Old Apr 18, 2002 | 08:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It doesn't have to be in the tube... altho that's certainly better. When I did my ram air intake, I didn't feel like extending wires or drilling holes- so I removed the sensor from the air box, and "hung" it near the filter. As long as the sensor reads the temp of air going into the engine, it'll be fine. (As in, you don't want to hang the sensor near the hot exhaust, or the hot engine block, or the hot radiator.)
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
