Backfire from somewhere but don't know where, Newbie here, Help me
Old Apr 1, 2002 | 11:20 PM
CamaroRules85's Avatar
Ok I have a 85 Camaro 2.8. I put another engine in it, Everything hooked up good and stuff. I go to start it, Starts good and idles fine, Right beneath the mass air flow sensor I put my hand and I rev my car and it bangs on my hand like smacks it and makes like a bang backfire noise, What is this? I took off my hoses from my air filter and eliminated the MAF, But where the hose hooks on to the throttle body from the air filters u can hear it coming out of there, We are chaning that piece tomorrow, We're thinking throttle position sensor or something in that piece, Also, we're thinking it could be out of time, It's at 17 degrees but it's supposed to be anywhere from 11-13. Thanks for the help u guys
Old Apr 1, 2002 | 11:56 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Defantly the timing, thats where I would start. I have mine set at 13 degrees.The best way to get the distrubitor bolt loose is with a swivel, 2 long extension bars and a 15 mm socket. You can get a swivel from wally world for like 5 bux.huuummm that name sounds familiar
Old Apr 2, 2002 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, CamaroRules85, you should really get together with 85CamaroRulz. He lives 12 minutes away from you, and amazingly enough, has the same EXACT problem! He just put a new engine in, too. What's more, he thinks it's the timing, too! And believe it or not, he ALSO thinks that the timing's at 17 degrees! Isn't that strange? (laughs) The world is full of coincidences, eh?
See his message below:
Originally posted by 85CamaroRulz
I changed it, It isn't my MAF. It knocks on ur hand right below where the Mass Air Flow Sensor is. So tomorrow we're checking out the part that has the throttle sensor on it. It's a whole piece. While I am at it, I am probably gonna get new plugs and wires. But we can't get the distributor bolt loosened. 9/16 is too small and 5/8 is too big, We're thinking it's metric, We even used that L shaped wrench, Didn't work, Email me at Heckman_R@msn.com.
Old Apr 2, 2002 | 10:06 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Yeah that was lame. Your name is almost the same too. His car is out of time too its at 17* I think lol. Anyway.
Now check vacuum leaks. About what RPM range does it backfire on? When my car did this it backfired from about 1500-2000 which really sucked but in all other ranges of the engine it was fine.
Old Apr 2, 2002 | 10:15 AM
KED85's Avatar
Maybe the timing was increased as it went faster down the drag strip.
IF you drive, backwards, on the same drag strip, the problem will be corrected.
Oh, pushing the car, sideways, down same drag strip, that caused the timing problem, increases the horsepower, as long as the wind factor is calculated into the final gear ratio formula.
Let us know the results!
Please keep us updated.
We hang on every response from ya.
Old Apr 2, 2002 | 11:17 AM
Car: 85 Camaro SC
Engine: V6
:sillylol: were too damn funny
Old Apr 3, 2002 | 03:41 AM
89camaroRSV6's Avatar
lol man... thats soo funny tomp,Karl...
lol sideways ROFL
but is our car equal to any v8 car if we raced it going backwards i wonder....
anyways i can run my car with timing @ 18* only thing is car idles bad ...i use 93 octane gas...but thats maybe cos of my mods....
maybe UR MAF sensor is gone.??? maybe the connector to teh MAF is gone as well...
my MAF was makin loud poping noises when the MAF went out...
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
dyeager535
Aug 28, 2015 08:10 AM
R3500
Aug 24, 2015 09:05 AM
db057
Aug 22, 2015 08:17 PM
