3.1 Liter help
Old Apr 2, 2002 | 11:32 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
3.1 Liter help
I have a question(not about my bird, about my GA with a 3.1) This may get locked cause it's not about my third gen, but i will try anyway. My beater/winter/grocery getter car is a 95 Grand Am with 84,000 on it. It just recently started to hesitate real bad, like a constant chug. I have replaced the IAC valve, it will eventually even out under hard accleration. But i mean pedal to the floor acceleration, and then it wont smooth out until about 60 miles per hour. I am thinking maybe a bad fuel filter? Does that sound right. It started out has a little problem, and now is a huge problem. Could the fuel filter start to go bad and then get worse. The car is in great shape, recent tuneup,new intake gasket,new trans lines, and now this. Any ideas?
I am not getting a code or light.
Thanks if you can help
Old Apr 2, 2002 | 12:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Welll..... if it had a tuneup, the fuel filter should've been replaced...
This 3.1, does it have DIS? (Distributorless ignition?) Will this problem get worse as the car gets warm? If so, I'm thinking the DIS's crank sensor might be cracked. If they crack, they run great, but as the motor warms up, the crack expands, and throws off the ignition system.
Although, you did say you weren't getting a code... I think a cracked sensor will throw a generic "DIS problem" code.
Pull the plugs and see if any look fouled, or otherwise "different" than the others, or different than a "normal" looking plug. This could tell you if you have a problem with your cylinders or ignition.
Could this be a vacuum leak due to an incorrectly tightened intake manifold gasket?
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
usafirebird
Sep 29, 2015 11:58 PM
