Tranny rebuild kits
Old Apr 3, 2002 | 05:02 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Tranny rebuild kits
I know this would probably be a question better asked on the tranny board, but I trust you 6ers a lot more. Where is the best place to buy a tranny rebuild kit, and how much should I expect to spend? I was just on the tranny board and happened to see that TomP had bought one a while back for $250. I know somebody else on the board just had theres rebuilt a month or 2 ago, where did you get the kit? Oh, and is the kit thesame for the 6 cyl 700r4 as it is the 8?
Old Apr 3, 2002 | 06:00 PM
Camaro_hunter_d's Avatar
Re: Tranny rebuild kits
go to summit. get a performer rebuilt kit. 2-300 sounds about right...
Old Apr 4, 2002 | 10:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, the kits are the same. GM did some minor differences between the V6 and V8 700r4. For instance, in one spot, the V8's got a thick sprag, but the V6's got a thin sprag and a spacer! The V8 also has a couple more clutches in its clutch packs, but everything will go into a v6 700r4. In fact, you can't find a rebuild kit for a V6 700r4, they're all engineless 700r4's.
If you want a generic "non performance" rebuild kit, which is probably what the guy put into my trans, you can find one at http://www.expressautoparts.com - carparts.com used to list one, before they merged with JC Whitney, so I imagine it's also at Express.
And $250 wasn't just the kit, I think the kit was $80, fluid pump was $60, torque convertor was $80? Something like that? Yes, you should replace the torque convertor when you rebuild a trans. Once metal filings get inside a torque convertor, they can't be removed unless the TC is physically taken apart- and then it can be cleaned, then welded back together. The TC on mine is a remanufactured one (opened, checked, cleaned, reassembled), and the old one was a core.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tonys91rs
Oct 10, 2015 03:31 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
