diagnostic test/service engine light question
Old Apr 5, 2002 | 06:59 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
My service engine light has been coming on lately when driving slowly up a gentle slope and when cruising about 70-80 on the autobahn. When the hill levels off and I let up on the gas a litlle, the light goes off. On the autobahn it just comes on for awhile no matter if I stay on the gas or let up. This happened tonight and my friend were freaking out thinking I was going to break down. ha ha, little did they know this happens all the time. anyway before I fall asleep on my keyboard, If I get it hooked up, will the fault still show up even if the S-E light if off, or does that light need to be on for the diagnostic program to read the fault. Cuz I'm sure when they test it the service engine litgh will be off.
Old Apr 5, 2002 | 07:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When "they" test it? Who is "they"?? I think you should test it. Here's something I just typed up:
Originally posted by TomP
You could search "check for codes" in the V6 forum (click on upper right hand of this screen, there's a search button).
Basically, look at your ALDL connector, below the steering wheel. Remove the rectangular cover. There's two rows of pins there; ignore the bottom row completely. On the UPPER row, look at the RIGHTMOST two pins.
With the car off, put a paperclip or piece of wire in the ALDL so you connect the RIGHTMOST two pins in the UPPER row.
Turn the key from "off" to "run/test lights" position- the position right before you would crank the engine. DO NOT CRANK THE ENGINE!!! You'll see your SES light up, and hear your electric fan come on.
The SES light will start to blink codes at you. It blinks each code 3 times. It always (well, it should always) start with code 12- "no distributor reference pulses". This is normal, because hey, the engine isn't running!
Code 12 is shown like this: Flash, pause, flash flash
An example of code 35 would be flash flash flash, pause, flash flash flash flash flash. Remember each code repeats three times. When there are no more codes, the ECM starts over, and will start flashing code 12 (and the rest of your codes) over again. If you have no codes, all you'll see is code 12.
Turn the key to OFF, and THEN, remove the jumper wire from the ALDL.
This info is also in the "3rd gen FAQ" in the "Miscellaneous" (last) section. Find it thru thirdgen.org's main page.
And yes, the ECM will store trouble codes for a while. They disappear after a certain internal... something like "after 500 starts of the engine and no repeated code". I've heard mechanics say "oh, well, if the SES light isn't on now, I can't diagnose it, if you get the light to stay on, come back"- but I think they just didn't want the job.
Old Apr 5, 2002 | 07:53 PM
Firebird90V6's Avatar
My 1990 3.1 did that for awhile, turned out to be the knock sensor setting off the code. Its goes out but is stored till i think you reset the computer(by disconecting the batter for 5 minutes). The knock sensor is easy to replace, also called Electronic spark control sensor i think. Try using a mid grade gas, i was told that more then likely will cause your car to do this, once you pick and octane level stick with it, dont jump around.
Old Apr 5, 2002 | 08:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
But, one problem; 85-89 2.8's don't have a knock sensor...
Old Apr 6, 2002 | 02:28 AM
Engine: 3.4
cool thanks. I won't be suprised if there's a few codes. (man was I typing bad last night.)
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
