hmm...weird engine noises...
Old Apr 10, 2002 | 12:56 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
today when i shut my car off, i revved it to 2k and turned off the ignition, kept my foot to the floor while it was revving down to let it have a little more air. when it got to about 250 rpms, i heard a metallic scraping sound for about 2 seconds, then the engine stopped with a series of violent shudders. it does this every time i turn it off. any ideas on what this could be?
Old Apr 10, 2002 | 02:16 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
hmm. My car did this last time when I first started it because I was away from home for a month. But it never did it the last 3-4 times I had it running.
Yours sounds like a problem you should get fixed if it happens everytime. Someone should knowwhat this is. But This does not sound good.
Old Apr 10, 2002 | 02:23 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
kinda sounds like it's deiseling, but never rreally heard of it on a FI engine.
Old Apr 10, 2002 | 02:27 PM
Camaro_hunter_d's Avatar
Yes FI engines CAN diesel. Sounds like maybe a dry bearing scrape?. High pitched squeel? but with the engine still spinning(RPM) there SHOULD be oil flowing. You MIGHT have a semi clogged passage.
Old Apr 10, 2002 | 03:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Why would you shut the motor off at that high of RPM's? Just curious.
Old Apr 10, 2002 | 04:32 PM
ChevyGuy87's Avatar
Engine: 4.0
i was thinking along the lines of a dry bearing, too. i dont get why it only does it for a second or two, and only when it's turning off though.
Old Apr 10, 2002 | 05:01 PM
I know when I had many a Carbed motors I would "rev" it right before killing the engine. I found it usually started a little easier. Maybe just a "myth" of carb's.. but it sured seemed to help to me... But FI cars.. not unless you are showing off.. and rev to 2K it not a "high RPM"... 5k is high.. 2K is a tip of the pedal...
Old Apr 10, 2002 | 05:06 PM
Re: hmm...weird engine noises...
I would release your foot from pedal. let the engine die. By pressing the pedal down you may have caused a "surge" and the engine tried to rev up... Hense noise.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
