Everything you ever wanted to know about wheels / fitment
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
How to Measure Bolt Patterns----> http://www.rsracing.com/tech-wheel.html#patterns
How to Measure Wheel Backspace or Offset---->http://www.rsracing.com/tech-wheel.html#backspace
How to Determine Vehicle Fitment---->http://www.rsracing.com/tech-wheel.html#fitting
Determine Wheel Caliper Clearance---->http://www.rsracing.com/tech-wheel.html#caliper
Typical Lug Nut Torque Specifications---->http://www.rsracing.com/tech-wheel.html#torque
Wheel Terminology---->http://www.rsracing.com/tech-wheel.html#wheeltrm
From RsRacings Website http://www.rsracing.com/tech-wheel.html
Since this answers alot of questions that are frequently asked on this board, I am going to make this a sticky.
You must have been replying as I was. Taken care of!
Car: 1989 Firebird
Engine: a monster
sweet
Brake setup also have different offset mounting surfaces. So a wheel that fits one car may rub on another with adifferent brake package.
Here are some guildline figures to calculate with.
PART1
Standard Non-1LE front -small bearings(10.5" rotor)
3.630"
1LE brake setup- large bearings (12" rotor)
*THIS IS THE FACTORY STANDARD FOR 245/50-16 tires on an 8"wide rim*
3.948" [+.318 offset, or just over 5/16"]
Custom Wilwood setup (RTFC)-large bearings alum hub (12.9" rotor) with a 3/16" wheel spacer for rim to caliper clearence
3.967" [+ .337" offset, or just over 5/16"}
13" C4 HD's on 1LE hub-large bearings(13" rotor)
4.248" [+.618" offset, or just shy of 5/8"]
13" C4 HD's on std hub-small bearings(13"rotor)
3.930" [+.300" offset, or just shy of 5/16"]
You can now see how a senerio like going from standard brakes to C4HD w/1LE hubs can change the backspacing by just over 1/2". Could mean the difference of someone using a 4.75bs front or a 5.25bs front on the same width rim.
part 2
Diameter does not change offset, width does.
So with the above figures on those perticular brake mounting surfaces and 8" wide rims, you should be able to simply add the width of the rim to the backside and subtract half the new rim width difference to the offset to match the same outer tire edge overall.
example- 8" to a 9" is 1 inch difference on the inner wall of the rim so half that difference is .5" or 13mm. Since the new rim is wider, the center line of the rim changes so a new offset calculation is needed.
We now start with a 9"rim that has a centerline (o offset) +.5" or +13mm inward from the 8" rim. Subtract the difference.
+5mm subtract +13mm = -8mm offset
So a 9" rim on Standard brakes would need a -8mm offset for maximum turning radius clearance without hitting the fender in suspension travel.
From what I have measured on my car and being so lowered, I would never go larger than a 9" wide rim and a 10.2" tire up front.
part3
Now factory IROC fronts 8" wide are 0mm offset and rears are -16mm offset.
A 8" wide 0mm offset rim can be spaced out as far as .525" safely without the tire coming into contact with the fender on a standard 10.5" factory brake setup. you can go further if you choose, but any more just be warned that the tire will contact the fender if the car compresses to low. Its your option, I am just stating helpful info
So in laymans terms-
Max outer offset of a 8" wide rim on standard brakes is +13mm.
So if factory fronts are 0mm, you have a range of 0mm to +13mm offset on an 8" wide rim. I have gone as far inward as -11mm with very slight acceptable rubbing at full lock where I back off just slightly and still have a very good turning radius. This range from +13mm to -11mm with an 8" rim is equivilent to the inside edge of a 9" rim that is 1 inch wider of course (or 1.000) I was replicating a .944" wider rim than the 8" when I was slightly rubbing. So another 1/2" to a 9.5" rim will really restrict your turning radius while remaining the outer edges ability to tuck.
Max offset of 1LE brakes is +5mm on an 8" wide rim
Now these spec are the outer most edge of the tire clearing the fender still. With the outer edge sitting here, the widest rim you can get going inward from this vertical line is a 9" rim with very minimal and acceptible rubbing slightly on the inner fender well (frame area) at full lock left or right with a 10.2" tire width which is about normal tire width for that size rim.
So now you want to jump up to a 9" wide front rim?
Then the offsets change due to rim width and centerline changes.
Specs for 9" wide front rims on standard brakes is 0mm offset.
Specs for a 9" rim on 1LE brakes is -8mm offset.
Now if keeping the tires ability to tuck into the fender properly is not a concern for you, then skies the limit. Anything sitting outermost then these specs will hit the fender if the suspension compresses enough so it you want to run a 9.5, then you can also run a 20" wide rim. There is no limit once beyond this vertical barrier. Its your choice, you are armed with the facts.
PART1
3.630"
part 2
part3
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
I was lookin through an old Car Craft mag (from 2000), and thought I might add what they wrote. The article was called The Biggest Meats For Your Muscle Car. The info they gave for 3rd gens is:
'82-'92 Camaros and Firebirds
15-inch: 15x8 with 4 1/2-inch backspacing front and rear. Use tires with an aspect ratio of 55 or less with a section width of 255.
16-inch: 16x8 with 4 1/2-inch backspacing front, 5 1/8 backspacing rear. Use tires with an aspect ratio of 55 or less and a section width of 255.
17-inch: 17x9 with 5 1/2 inch backspacing front and rear. Use tires with an aspect ratio of 40 or less with section widths of 255 front, 275 rear.
18-inch: 18x9 1/2 with 5 1/2-inch backspacing front, 18x10 with 6-inch backspacing rear. Use tires with an aspect ratio of 35 or less with section widths of 275 fron, 275-295 rear.
I hope this helps someone.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
http://www.rims-n-tires.com/info_spe...20/%20Comparer
heres a good link on comparing different wheel sizes with tires. it will tell you how much further in or out wheels will stick out with different offsets and such. you choose the tire/rim size and offset and compare it to another rim/tire size. its pretty sweet
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Just thought I would chime in and say the RSRacing links no longer work. Delete this when they do.
Car: 91 Z28
Transmission: TH700-R4
Re: Everything you ever wanted to know about wheels / fitment
my iroc replicas are bolt on with 245/45/17 tires.
hawks third gen has em but they aren't cheap.
i just wish i could have gotten 18's but $$$ is tight after i replaced my motor. and installed new seats, steering wheel, b&m shifer, and got a few tickets. just the bare essentials
i think it would look sweet with a lowering kit but don't know how much i should drop it.
Car: 1991 Z/28
Engine: 406 T.P.I.
Axle/Gears: Richmond 3:73
I have American Racing Rebels 17" x 9" with 1" wheel adapters on front and back. Front 245, Back 275 Riken Raptors. This application brought all four tires perfectly flush to the body panels for a nice aggresive stance.
Car: 89 Iroc-z
Transmission: TH400
specs for 4th gen wheels and corvette wheels can be found here at Skulte.
http://www.skulte.com/adapterfaq.html
Thanks!
no way unless you have a 93-02 axle already installed ...15x10`s on a stock length 3rd gen axles are usually 5.5 bs....with ALOT of hammering/reshaping, one of the members here managed a 6.5
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
So why is there a different offset on the GTA wheels from front to back? I'm guessing it has something to do with fitment under the wheel wells.
I have a screwy problem. I have Ed's LS1 brake kit on my car that currently requires me to run 1/8th inch spacer on the front to clear the calipers with the GTA rims. It's real tight in there and my left wheel rubs the wheel well in hard right turn. Anyway, I have bent rims and am shopping for new wheels. I want to stay with 16 inch wheels and I would like to be able to do a 4 wheels rotation with the tires.
How do I know what to order?
Is this correct:
Is this correct:
- 5 inch BS, 5X4.75 bolt pattern.
Something to think about when you order tires, I`m currently running 29x11.50 LT hoosier quick time pros...that is dot sizing. I run them on a 10 inch rim, the advertised section width is 11.9 But, that is on a measured rim of 8 inches.
To calculate the section width change on a different size rim than the factory measured wheel use .4 inches PER inch of rim increase. or subtract for rim decrease
Example: My QTPs on a 8 inch rim would be a 11.9 section width but because I use a 10 inch rim it would be like this...
11.9 + .4 + .4 = 12.7 section width.
Just thought it would help anyone trying to stuff tires / wheels
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Here is a very usefull page for adapting wheels to a Third gen. They have all the popular swaps listed and the spacer size needed to do it.
After looking at that just select the right tire size.
OTOH, most people seem to like aftermarket wheels that stick out to the fender lips or more in the back, so they tend to run similar backspacings as the front. Personally, I don’ think it looks right.
Is this correct:
Do a search on this board, I know I’ve posted how to figure out offset/backspacing/rim widths/tire widths in detail a few times, but it’s been a while.
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
I would like to see pics of this as well please....
Here is a template I made of the 1991/1992 Z28 wheels versus a C5 Corvettes rims. Tire sizes outlined are marked on the image, the tires on the C5 rims are the skiniest you can fit I think (or almost anyways) and a 1.5" spacer was used in the back which actually puts most of the added tire towards the inside. So if you track back to the document from Skulte you can see why they recommend a 2" spacer despite the 1.5" being what initially apears to make more sense.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
What are the torque specs for the wheelnuts of original 16 inch Formula wheels?
As I live in The Netherlands, Europe, I have a metric torque wrench in newton-meters, Nm.
Thanks.
Thanks.
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
http://cgi.ebay.com/ebaymotors/WHEEL...mZ120389602923
So with these spacers i can put corvette wheels on my 84camaro?
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have an 84 Z28 as well and have IROC wheels on it. Do I need to do anything to make them work properly? They seem to clear everything, but I have no adjustment left on my strut mounts and wondered if that was the reason.
Car: 84 Z28, 05 Mazda 6
Axle/Gears: 3.42 Open
I have an 84 Z and I just got a set of used 18x8 Chrome Iroc's (I LoveThem) the tires that are on them now are toast and only 235's I was trying to figure out what the better choice of tire would be. I have read that some have 245/40's on front and 255/40's rear and some say 255/40 or 255/45 all the way around. I just put KYB GR2's all the way around and new stock springs in the rear, the front springs were replaced before I got the car and I now have that hi ridin look happening but I think it's only because the current tires are flat. Any light you guys could shed would be greatly appreciated the Z's down until I get some new slippers.
Yes you can you can also put 4th gen rims on with the 2" adapters, and Shuanm Iroc wheels should fit fine if you have no adjustment left I would look into an alignment and or having your suspension checked out to make sure there's nothing busted, or bent. Also some Iroc wheels had different offsets front and rear, I believe they are marked though so as long as you didn't miss the markings you should be good to go. Good luck.
Car: 84 Z28
I did put the fronts on the front and so on, but I don't have the thin spacer that goes on the back. Do I need it with drum brakes, or will the drum serve as the offset? I didn't really think the wheels would be the problem, but who knows with as many different setups as there are. I bet my alighment shop doesn't check caster. It doesn't track well, or recenter after a turn. I have a new gearbox and rag joint.
Last edited by shuanm; Apr 2, 2009 at 03:05 PM. Reason: Ooops Breaks would not stop you like brakes.
hey im working on my 1989 camaro RS im redoing all my car from chasis to windows and i bougth some corvette rims aluminum polished 19x10 rear and 18x8.5 fronts and i would like to know what tires do u recomend me and where to get spacers at a good price and spacer sizes thanks!!
Car: 86 Camaro berlinetta sport coupe
Engine: 2.8 soon to be 4.3
Transmission: T5 soon to be 700R4
just curious, im lookin to getting the 20 inch iroc wheels for my camaro, but not sure what tire size, well actually the aspect ratio of the tires, i work at discount tire and have unlimited access to the wheels, but i was just curious on the tire size, i have mine lowered 1.75 inch and was just looking for someone with expirence in this field im trying to get into, lol.
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Erick I had the wheels you have with 235/40 in front & 285/30 in rear with 2" adapters all around, needed to do a little hammering in inner fenderwell, sold those a few months ago. Got another set recently and put 255/40 up front & 275/35 in rear, I've heard guys going bigger front and back though. Camarobird a member named Sickness has experience with 20", maybe you can track him down.
Just put on a set of GTA Rims on my 1987 Trans Am with 245-50-16 tire the fronts rub at full lock any suggestions other than odwnsizing my front tires would wheel spacers work?? and yes the front rims are on the front and the rear are on the rear
I'm not sure why people find this such a big deal... just don't turn the wheel all the way against the lock. If your car originally came with 15's (215/65-15), then it had thinner stops in the steering box so you could turn the wheel farther then cars that came with 16's. Spacers might help that but will make the wheels more likely to contact the front and back of the wheel wells which I think can be much more annoying.
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
I'm going to probably run a set of weld prostars on my formy and a friend has 15x10's with 5.5 in backspacing and a 295/50/15 tire and they stick out a hair but dont rub. can I run the same tire on a 15x10in rim with 6.5 backspacing on my 89 formula? the car is lowered about 2 in in the back
Car: 1992 Z28 Convertible built 07/01/92
Transmission: 5 speed
Axle/Gears: 3.08
I'm looking at a set of 17's for my '92: 5x120 bolt pattern, front - 8" w/35mm offset, rear - 9" w/30mm offset. Do I need 5 1/2" backspacing for these to fit properly?
hey guys quick question,im lookin to put a set of weld super roadhawk wheels on the back of my 1992 camaro. the measurments are 16.5x10 5on 135 mm backspacing is 4.625. will they fit?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
I have a set of Ronal R-15's. They are 17x9.5 and they have 5.5 inches of backspacing. I can put the rims on my 1991 formula with 1/4 spacers, but they still touch the tie rod end, just barely. I have considered a larger spacer but am concerned with wheel balance and lug stud stress. Is there a spindle and brake combo where I could make up for the spacing issues or perhaps a rotor that has a thicker hub? I love how these wheels look.
you pretty much need a 0 offset for any front rims wider than about 7.5-8", which means that you'll need a 1/4" spacer. If you're hitting the tie rod with that I'd look at if there is any clearancing that you can do to make it work rather than look at a thicker spacer.
A thicker spacer will put the wheels/tires in a weird place (both WRT to appearance and suspension geometry), and the other thing is that 3/8 to 1" is that area where there is no really right way to do it. Really too thick for a normal spacer but not thick enough for a strong bolt on (somewhere around 3/4-1" you can start getting them made from steel, but they don't really work out of aluminum till you get to 1-1/4"). The best thing that you can do is go with stronger, longer aftermarket studs and then custom machine spacers that both register on the original hub, fit the studs tightly supporting them, and have a machined hub surface for the wheel hub to register on also, but I don't know of anyone selling them.
Car: 1986 Trans Am
Engine: LG4 305 5.0L
I just bought OEM 98 trans Am chrome five star rims 16x8s for my 86 Trans Am and ready to buy adapters. The tires are 45s up front and 50s in the rear, would 2" adapters all around be the best choice. If any of you have done this swap please help Thanks!! Oh and if you know the best place to buy in the SoCal area..
Car: 87 GTA
Just thought I'd share these 2 pics to show wheel fitment with a 4th gen rear end.
The car is a 91 TA....
1st pic is of a stock 95 Firehawk wheel & a 275/40R17 tire on the 95 Firehawk rear end, under the 91 TA.....
And on the other side of the same 91 TA at the same time, is the stock 16" 3rd TA wheel with a 245/50R16 tire.....
These pics show that the Firehawk wheel & tire sit in by 1/4" and the stock 91 TA 16" wheel with 245/50R16 tire sets PERFECTLY flush. It doesn't push the weighted string out & there is no gap between the tire & string either.
And that is ONE string, weighted on both ends. So it was never moved between each pic & lined up with the center of each axle/wheel.
This is good stuff! i'm currently deployed to Afghanistan and have a friend doing some work to my 83 camaro z/28 and I've been searching online for wheels and when they ask about back spaceing I've been like I have no idea I'm in Afghanistan and can't exactly measure anything so this is great thank you.
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
When you say "backspace" does that mean you have 10 lugnuts? I make over 400 horsepower and am looking for wheels.... I do not think it's a good idea to have any spacer or adapter with the horsepower.
I went to the first store to talk about wheels, a few things came up: One, he said you can't put Vette replica wheels on my car, LIE...... Two, he said American Racing don't make Iroc Replica wheels, that it's "OE Racing" a sister company...... and THREE, probably my biggest concern, he said that a company called "OE Replica" is china made wheels and to stay away from these wheels. Says he had 3 Camaros.....
I like the 18 inch Iroc idea. They don't have the same offset? What gives... The factory Irocs have different front/rear. I would prefer getting 19.5" in the rear....
