Pic's of 3rd gens Camaro's with drag wheels?
Old 09-03-2010, 10:56 PM
  #51
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Pic's of 3rd gens Camaro's with drag wheels?
84 z28--
Have any rear & side pics?
Any mods to the wheel wells??
Great looking stance!! Great looking Camaro!!
I was told I can't go bigger than 8" wide wheels or the tires would rub the inside wells unless it was cut out.
Old 09-04-2010, 11:33 AM
  #52
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
It looks ok, but I'd rather have a cowl scoop.
Old 09-06-2010, 06:33 AM
  #53
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
centerline comp quailfier up front and stock 91 wheels in the back till i burn these et's off them i'm gettin either 8 or 10's for the back
Old 09-06-2010, 06:59 AM
  #54
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Originally Posted by t-top havoc
84 z28--
I dont have any good pics of the rear but i have a couple of the side view. You can go with a 8" rim and 4.5 backspacing and you will be fine with a 275 tire. I have seen it done on this board a number of times. When you move to a 15x10 you have to cut up the wheel well. This is what i had to cut out to make the rims and tires fit.
https://www.thirdgen.org/forums/whee...get-15x10.html
Attached Thumbnails Pic's of 3rd gens Camaro's with drag wheels?-100_7452.jpg   Pic's of 3rd gens Camaro's with drag wheels?-100_7466.jpg
Cootchybandit (01-15-2021)
Old 09-06-2010, 11:09 AM
  #55
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
84z28 - I like that the rear wheels don't stick out on your car and that they tuck in nicely. I'd like to get about the same effect, but I'd like to run a smaller rim since I'm only interested in getting 15/275/60"s on the rear of mine without hitting anything or modding.
I've been looking at the Centerline Polished Fuel wheels, and they have a 15"x8.5" wide wheel with a 5" back set and a +13mm OFFSET available.
So how will this positive "offset" effect the fit of the wheel/tire?? Also on some wheels, they don't even list a back set, just "off set" - what's a good off set wheel for the rear of a Thirdgen that'll tuck in as far as possible without modding (in a 15" wheel)??
Old 09-23-2010, 09:38 PM
  #56
Car: '87 Camaro
84 z28 & Stephen--
Thank You for the info!! This is definitely something I saved in my "favorites" on the computer. Now I know what we may be in for when we decide on wheels & tires!!
WILL do it for sure if there's rust.
Old 09-24-2010, 08:31 AM
  #57
84 z28's Avatar
Car: 1984 z28
Engine: 355
I know on a 15x8 you usally want a 4.5 backspacing with the extra 1/2 of rim and backspacing I dont know if it would rub or not. I forgot what the offset will affect in your case but it is where the hub mounting surface sits in the rim but I believe most 15x8 rims with 4.5 backspacing have a 0 offset. My 15x10 have a 6.5 backspacing and are a +25.00 mm offset.
Old 09-24-2010, 09:10 AM
  #58
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
a 15x8.5 with 5" back spacing centerline wheel will fit no mods required. i had a set of warriors on the car for a weekend once with those exact dimensions.
Old 09-24-2010, 10:31 AM
  #59
Confuzed1's Avatar
Car: 83Z28 HO
Did the set of warriors also have a +13mm offset too?? -Or were they "0" offset? You see, that's my dilemma...13mm is close to 1/2", so I might end up with essentially a 5.5" backspaced wheel, or am I over thinking this? Why does a wheel need to have both an offset and a back set anyway?? It doesn't make sense to me.
Old 09-24-2010, 10:35 AM
  #60
mw66nova's Avatar
Engine: 7.0L
you're over thinking this. it's "5inch backsping OR13mm offset" and if 0 offset is 4.5", then 13mm offset would be 5". put a straight edge across the back side, and measure to the wheel flange, see what it is.
Old 09-24-2010, 11:02 AM
  #61
84 z28's Avatar
Car: 1984 z28
Engine: 355
Offset is where the the center line of the rim meets the hub mating surface.
Backspacing is where the hub mating surface is measured to the outside of the back of the rim.
The two are completely different and both matter.
Old 09-24-2010, 12:07 PM
  #62
Confuzed1's Avatar
Car: 83Z28 HO
Ahhh...Ok, so they're talking about the same thing then? It's really just saying I'll end up with a 5" back set as I'm trying to understand it. Seems to me that if you increase the back set on any wheel, the hub flange needs to move outward (which increases "offset") to make up for it regardless....is that the right way to think about it?
Old 10-12-2010, 11:28 AM
  #63
Want a 3rd gen's Avatar
Car: 88 Iroc
Engine: LM7
Transmission: TH 400
Axle/Gears: 12 bolt 3.91
nice cars!
Old 10-12-2010, 07:27 PM
  #64
mw66nova's Avatar
Engine: 7.0L
they are different, but they measure the same type of thing, just using a different concept. offset on a 15x8 wheel with 4.5" backspacing is zero, but offset using a 15x10 wheel with the same backspacing is ~25mm. a 15x10 with 5.5" backspacing would be zero. backspacing is a much easier measurement to use, and is what's mostly spoken of in drag racing since regardless of the width of the wheel, backspacing won't change. it's ALWAYS the distance from the hub flange to the inside wheel lip. whereas offset changes based on wheel width.
Old 01-18-2011, 09:00 PM
  #65
Thug Life's Avatar
to bump this thread up here is my car with pro convo's
I need your honest opinions
Old 01-18-2011, 09:04 PM
  #66
Thug Life's Avatar
oh btw the rear tires are 295/50/15 and 225/60/15 up front will change the front to 205/60 soon
Old 01-18-2011, 09:15 PM
  #67
84 z28's Avatar
Car: 1984 z28
Engine: 355
Back rims have the wrong backspacing. Other then that looks good.
Old 01-18-2011, 09:25 PM
  #68
Thug Life's Avatar
well the problem was if I want to use 10" rear it must have 5.5" B.S but centerline doesnt have pro convo's in 5.5" they have them in 5"
Old 01-18-2011, 09:36 PM
  #69
84 z28's Avatar
Car: 1984 z28
Engine: 355
You dont have to have 5.5 bs. You could of went 6-6.5 bs spacing if it was available.
Old 01-18-2011, 09:38 PM
  #70
Thug Life's Avatar
well it doesnt matter that much now I might go with TTII or just order rear centerlines with the correct back space
Old 01-19-2011, 07:07 AM
  #71
mw66nova's Avatar
Engine: 7.0L
convo pro's are a badass wheel, but i agree, wrong backspacing and it looks a bit r*dneck to me
Old 01-19-2011, 07:17 AM
  #72
Thug Life's Avatar
ok I decided to ditch the TTII idea out of my head and will order 2 wheels 15x10 with correct back spacing but whats the correct back spacing for them?
Old 01-19-2011, 07:42 AM
  #73
84 z28's Avatar
Car: 1984 z28
Engine: 355
5.5 , 6.0 , 6.5
I would personaly only go for 6-6.5 bs.
Old 01-19-2011, 07:44 AM
  #74
Thug Life's Avatar
5.5 , 6.0 , 6.5
now it has 5" B.S and you can see in the pictures it sits out like an inch or little bit more
Old 01-19-2011, 08:13 AM
  #75
84 z28's Avatar
Car: 1984 z28
Engine: 355
Whats your point. Your tires bulge more then the rim sticking out. You wanted a 295 then thats what hapens. Most people that have 15x10 rims go with 5.5 backspacing. That eliminates most of the work to the inner fender. In my eyes 6.5 is ideal but you have to cut and re shape the inner fender. Get a 15x8 and put a 275 on it and you will get the same look with less issues.
Old 01-19-2011, 08:47 AM
  #76
Thug Life's Avatar
I toke these pictures I hope they will explain what I mean
I
Attached Thumbnails Pic's of 3rd gens Camaro's with drag wheels?-13.jpg   Pic's of 3rd gens Camaro's with drag wheels?-12.jpg   Pic's of 3rd gens Camaro's with drag wheels?-14.jpg
Old 01-19-2011, 08:49 AM
  #77
Thug Life's Avatar
what if I toke the 15x10 with 6.5" B.S and instead of cutting I put half inch or an inch spacer will that work?
Old 01-19-2011, 09:32 AM
  #78
84 z28's Avatar
Car: 1984 z28
Engine: 355
6.5 bs with a .500 spacer and you would have 6" bs so yes it would. Dont get or use a 1" spacer.
Old 01-24-2011, 08:49 PM
  #79
Car: 88 Iroc
Engine: LM7
Any running a 15x10 with a 6 inch backspace? Post pics if you do!
Or a 15.9.25 with a 5.5 BS?
I am about to order wheels and need to decide between the 2
Old 11-16-2011, 10:58 AM
  #80
91RsNate's Avatar
Car: 91 Camaro
Engine: 383
Transmission: th-350
heres mine, 15x4 with 165 80 15 front and 15x8 with 4.5bs rear with 275 60 15s. need to lower it a bit in the rear.
Old 02-23-2012, 04:34 AM
  #81
88PontiacT/A's Avatar
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Just to clarify for those who may still be confused about the difference in wheel backspacing and offset:
http://www.tirerack.com/FAQ/results....gory=Wheels#66
if you click the word "offset" it will show a drawing of a wheel which will give a better visual of how these are measured.
Old 04-29-2012, 07:46 PM
  #82
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 350/IRON DART 200
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 4.88
Nice wheels...What brand are they?
Old 04-30-2012, 10:29 AM
  #83
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
Matt (mw66nova), 85sc5 and 91RsNate
You guys have the set up I want, while retaining streetable status.
1) Rears, was there any modifying for the rear wheel wells?
2) With 165's up front how is it during normal driving, parking & turning?
Old 05-15-2012, 06:38 PM
  #84
Car: 88 Iroc
Engine: LM7
Old 05-16-2012, 11:31 PM
  #85
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
What diff, tire and wheels specs r u running on that rearend ?
Old 05-17-2012, 06:18 AM
  #86
Car: 88 Iroc
Engine: LM7
Opps, I guess I forgot that info!
Strange 12bolt stock 3rd gen width
LT1 rear disc brakes
Weld RTS 15 x 10.275; 6.5" back spacing
MT 28 x 10.5 slick
Old 05-17-2012, 06:31 AM
  #87
mw66nova's Avatar
Engine: 7.0L
need to cut out the bump stops and do inner fender massaging where the lca mount is.
Old 05-17-2012, 01:33 PM
  #88
robg91z's Avatar
Engine: 350ci TPI
MT 28 x 10.5 slick
Looks awesome.. I have a fourth gen rear end on mine but idnt no what back spacing to go with so the wheels have tuck into the fender. I got some et drags 28x10.5 for free and i wanna mount them up but idnt know what wheel spec to get to get the perfect fitment
Old 05-17-2012, 02:13 PM
  #89
mw66nova's Avatar
Engine: 7.0L
if you have a fourthgen width rear, look at a 15x10 with 7.5" backspacing
Old 05-17-2012, 03:56 PM
  #90
Car: 88 Iroc
Engine: LM7
Originally Posted by robg91z
Looks awesome.
We went at it a slightly different way but got the same results as mw66nova
Rear plastics still fit too
Old 07-12-2012, 08:25 PM
  #91
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Hello everyone, For those running a 15" x 8" wheel with 5.5" bs, Did you have to do any modifications to the inner fender? I have a set of prostars and they seem to be very close to the inner fender. I bought 3/4" spacers and that gives me lots of clearance, but I'd rather not run spacers if I can get away with it. I haven't tried the fitment with tires mounted. What would be the best tire to run on these wheels... I'm thinking 275/60/15, or 275/65/15.
I currently have mickey thompson sportsman d/r 28/12/15 on stock z28 rims... and no clearance issues.
Mickeyruder (08-01-2019)
Old 07-18-2012, 12:46 AM
  #92
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
How about a 29x12.5 15 sportsmen all tucked under nice and neet
on a 10.275 x 15 wheel fits like factry..(Now)
I did have to use off set bushings for the LCA
DROPPED the car down about 2" inch ..looks sweet.
Old 07-18-2012, 06:51 AM
  #93
mw66nova's Avatar
Engine: 7.0L
looks good. do you intend to keep that old skool bias ply on there or go with some modern radials?
Old 07-18-2012, 07:24 PM
  #94
this is the thrash set of tires could not pass them up brand new for $200
this is the tallst set i could fit with My GFX good for mock up and beat up!
the drag Radials are 1 inch shorter at 28"tall and 1 inch wider with the same cross sec... 13"
and the sportsmen pro, wrinkle wall tires, bite better. to start with
almost has good as the ET streets. also a non Radial tire.
But.
doing the same thing has i did with the drag lites, buyn 2 more rims for the Radials
will be posting a add for the 6 weld drag lites all 15"
2x 3 1/2" (coopers tires new)
2x 8" (et streets tires new)
2x 10 (mickytomson tires 3/4 gone)
Tires are like shoes..ya can never have too Many..
so unless mom is still buys your shoes...why only have one pair. it's only money
just shop is all
Old 07-22-2012, 02:11 PM
  #95
just scored another set of new Mickytomson Radial front runner tires
with the flame patrn in the tred..$150 for the set.. 50%off
has long has i paid $420 for the 325/50/15 drag radials
so
also got the newr Micky Drag Radial rear tires.. it's all about dealing
update: sold the better then new weld drag lites for $600. had them for over 20 years..lol
there on a G body now... kid loves them..
Old 09-11-2012, 07:32 PM
  #96
gad
gad's Avatar
m/t drag radial 15x10 rear 275-60-15. 15x7 front 225/60-15
Old 09-11-2012, 08:46 PM
  #97
FJA1791's Avatar
Car: 1990 IROC-Z
Weld Racing Vitesse RT... M/T drag radial 275/60/15 on 15x8 5.5 B/S...205/75/15 on 15x5.
Attached Thumbnails Pic's of 3rd gens Camaro's with drag wheels?-2012-07-13-06.58.29.jpg   Pic's of 3rd gens Camaro's with drag wheels?-2012-07-13-06.59.04.jpg
Old 09-21-2012, 07:06 AM
  #98
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Are you sure on this info? Im about to make an order for 15x10 with 6.5 and .500 spacers
Old 09-21-2012, 11:11 AM
  #99
bracket rs's Avatar
new shoes
Old 09-27-2012, 08:44 PM
  #100
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Sizes please ^^
Quick Reply: Pic's of 3rd gens Camaro's with drag wheels?
