Tires?
Old Sep 20, 2007 | 01:49 PM
IrockanIroc's Avatar
Car: 1989 Iroc z28 TPI Camaro
Engine: 350 5.7 TPI
Transmission: Automatic
Tires?
Hey need new tires On my 89 Iroc whats the Best tire out there and then whats the best for the money?
Old Sep 20, 2007 | 01:59 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: Tires?
What are you looking to do with your car? If your just looking to drive it everyday, the best tire is one that's going to last you awhile. Do you drive it in the snow?
Old Sep 20, 2007 | 02:19 PM
OneManArmy's Avatar
Car: 1988 GTA
Axle/Gears: 3.70
Re: Tires?
Best for the money?
https://www.thirdgen.org/forums/afte...e-fuzions.html
hands down.
now "The Best" tire is going to require a little more information as those tires usually get very specific with thier application. (I.E. Drag Radial, Snow Tire, etc)
Old Sep 20, 2007 | 05:30 PM
Engine: 350 5.7 TPI
Re: Tires?
The ones I want will be mainly for everyday including snow I already have mess around tires and two slicks for drag but theyre all older and bit dry rotted so for future referance if I wanted drag tires and then say street racing and then everyday so that would be 3 sets.. right?
Old Sep 20, 2007 | 07:06 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Tires?
I worked at firestone. Let me tell you, if you can talk them down a little, Fuzion Zri's are the way to go. The are a nice directional tread pattern with big enough blocks for traction, but good wet traction too. Also, they have a diesel sidewall (always a bitch to mount).
On the other hand, I would personally stay away from the Hri's. I have seen so many cars come in where the HRi's have gone bad prematurely. They are a cheaper tire, so even though they carry the Fuzion logo, they suck. THe sidewalls are still stiffer than most touring tires, but the tread always seems to scallop. This leads to a vibration in the seat and the steering wheel. They also wear very unevenly. I have seen 2 cases of the HRi where the belts were letting go inside, and there will be big diagional crest's and troughs.
Also, firestone sells them to compete against the chinese tires e.g. nankang, nexen, ect.
Old Sep 25, 2007 | 09:10 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Tires?
I can't complain about my Goodyear GS-D3's. Fantastic in the wet.
Old Sep 25, 2007 | 09:28 PM
Red92RS's Avatar
Car: 1992 Camaro RS
Re: Tires?
I would suggest BFGoodrich KDWS tire which has great dry, wet & snow traction. Now i just found out today that BFG has a new tire coming out called the GForce Super Sport A/S which is supposed to have the same great traction for snow also but is an All season tire. If i get more info on the Super Sport A/S i will let you know.
Old Sep 26, 2007 | 07:00 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: Tires?
Plus 1 for the KDW's, outstanding summer tire. The wet traction is fair, and I wouldn't dare drive this car in the snow...
Old Sep 26, 2007 | 12:23 PM
pdturbo's Avatar
Car: '92 Z28 1LE
Re: Tires?
I've been running the G-Force KDWS for the last several years and have been very happy with them in daily driving as well as the occasional road course track day. They where even suprisingly good in the snow for the first couple of years but not so much after that.
I'm due for some new tires now and am considering the Bridgestone Potenza RE960 A/S. Does anyone have any experience with these?
Old Sep 26, 2007 | 04:01 PM
TMZIrocZ350's Avatar
Car: 89 IROC
Engine: 5.7L
Axle/Gears: 3.70
Re: Tires?
I have been running the Toyo T1R's. No complaints, very nice dry and wet traction. Bit pricey, but I have them on 18's. On stock wheels they are probably competitive with other companies pricewise.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
