what size rims
Old Feb 15, 2008 | 05:05 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
what size rims
i want to order some new rims but not sure what size the factory is its an 84 t/a any help would be great cause i would like to order asap
Old Feb 15, 2008 | 05:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: what size rims
most likely 15x7
you can do much better, what are you looking at?
Old Feb 15, 2008 | 05:24 PM
AmorgetRS's Avatar
Re: what size rims
15x7 or 14x6(? not sure on the width of the 14s) like said above.
However, those are not stock Trans Am rims you have pictured. They are Camaro rims.
Old Feb 15, 2008 | 08:04 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: what size rims
was looking at these i'm looking at geting something in black. and if i get these and the turn out not to suite me its not a bigg loss becuase there inexpensive
http://www.jegs.com/webapp/wcs/store...51048_-1_36662
if you know of something better let me know
not looking to spend over 250 for all
Old Feb 15, 2008 | 08:54 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: what size rims
what does it mean by bolt circle
Old Feb 15, 2008 | 09:29 PM
AmorgetRS's Avatar
Re: what size rims
How many lugs and the distance between them.
http://www.midatlanticmotorsport.com/bolt_circles.htm
A Thirgen is 5 x 4.75
Old Feb 15, 2008 | 09:42 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: what size rims
thanks and im guess that front and rear would be the same. and also a 4" rear spacing is fine to,
also i hate to be a pain but what size lug would i need.
Old Feb 15, 2008 | 09:58 PM
AmorgetRS's Avatar
Re: what size rims
What width are you going with?
Old Feb 15, 2008 | 10:07 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: what size rims
problably a 7" cause i just bought a new tire and dont want to have to waste that.also worried about rubbing
debating on these two
http://www.jegs.com/webapp/wcs/store...54162_-1_36662
Old Feb 15, 2008 | 10:46 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: what size rims
the pic you posted is of a camaro wheel
but that doesnt matter
factory wheels on these cars in 82-84 were 14 and 15
7" width in virtually all cases
you can put basically any wheels you want on it
you are making this way more complicated than it is
backspacing will be the biggest worry, if you were to get very tall or very wide wheels/tires
but with 14 or 15 and normal width like you are talking abotu then you dont need to worry about backspacing
are you planning on stock, or aftermarket ?
good luck
Old Feb 16, 2008 | 02:22 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: what size rims
well i got it all together and went with this
http://www.jegs.com/webapp/wcs/store...-1&showValue=3
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
Linson
Sep 21, 2015 01:08 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
m00n420
Sep 11, 2015 02:39 PM
