Would these size tires look good on my car?
Old Jul 22, 2008 | 09:32 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Ok i will be getting some new tires soon! My dad has a mustang with bfg's and he would give me the rear ones and i will buy front ones.
these are the sizes i was looking at!
Front 205/60/15
Rear 265/50/15
thanks
kevin
Old Jul 22, 2008 | 09:51 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: Would these size tires look good on my car?
I don't think so. Something about a 3400lb car with skinny tires on the front....and tall ones on the back
Old Jul 22, 2008 | 09:55 PM
DirtyCanadian's Avatar
yeah it looks not bad and would fit personally i would look for wider tires
Old Jul 22, 2008 | 10:19 PM
Well the wall on the front will be like 3 1/2 in and the back will be at 4 in.
Then what do you mean by wider 60's in the front 50's in the back.
kevin
Old Jul 24, 2008 | 05:17 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
rear tires would only be 20mm taller. 10 on top and 10 on bottom... wont even be that visually different.
Old Jul 24, 2008 | 05:23 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
kevin
50 and 60 are the tire profile. If you have a tire that is a 275/50-15... then the tire is 275mm wide and 137.5mm tall since 50% of 275mm is 137.5mm. The tire would be 137.5mm high from the edge of rim to the top of the tread.
Your front tires 205/60-15 are 205mm wide and 123mm tall from the rim to top of tire.
Your rear tires 265/50-15 are 265mm wide and 132.5mm tall from the rim to top of tire.
Last edited by Xlr8torZ28; Jul 24, 2008 at 05:28 PM. Reason: Automerged Doublepost
Old Jul 24, 2008 | 07:39 PM
avro206's Avatar
Car: 89 Formula
pretty close to 1"----very visually different...to me anyways
Old Jul 24, 2008 | 09:20 PM
Well ya i know that but would it look good with that set up?
kevin
Old Jul 24, 2008 | 09:55 PM
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
I like the idea of having as big (tall AND wide) a tire as you can get on the rear,but I would stick with the stock size in the front. The "big and littles" look good on, say a Nova or an early 'Stang but not on a third-gen IMHO.Also,too small a tire on the front my take away from the handling quality of the car.
Old Jul 25, 2008 | 02:08 PM
I want a tire that will let me handel good! I have already the rear so what size in the front?
kevin
Old Jul 25, 2008 | 08:50 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Need a 225 or 235 on the front.
Old Jul 25, 2008 | 11:12 PM
avro206's Avatar
Car: 89 Formula
kevin
by making the tire heights so uneven--with different profiles--I don't see how it would handle good at all. Not to mention they are 15" sized.
Low in front and jacked up in the back does not equal good handling. Just save up foor some IROC wheels and 245/50/16--they handled great with that combo.
Just my 0.02
Old Jul 26, 2008 | 02:33 PM
rsrookie's Avatar
Engine: 305 Jasper
TRUE DAT!!
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
colton_carlson
Mar 8, 2019 12:21 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Linson
Aug 21, 2015 02:12 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
