anyone running boss 338 rims
Old Oct 28, 2008 | 08:47 PM
firbster's Avatar
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
im lookin at these rims and was wondering if anyone here might berunning them ? there 18x8 front and 18x 9.5 rear. now ihave been told that they will fit but im wondering if anyone here has them???
Old Nov 28, 2008 | 02:03 PM
Corkyscrewed's Avatar
Re: anyone running boss 338 rims
http://store.mrt-direct.com/boss338wheels.html
I hope this helps!
Old Nov 28, 2008 | 02:08 PM
IROCFAST's Avatar
from the measurements given on boss's website, looks like you are good to go.
Old Nov 28, 2008 | 02:12 PM
Stephen's Avatar
Car: 87 GTA
Why just 8" up front? My 9" Snypers with 275s fit great, no adapters & do not stick out any.
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just make sure they have the correct bolt spacing, mustangs use 4.5 on 5 and 3rd gens use 4.75 on 5
Old Nov 28, 2008 | 07:49 PM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
they are the right bolt spacing, the only thing is the offset , there a 5" bs and i thought it might be a bit tight on the outter lip... the reason i wouldnt go to the 9.5 on the front is the backspacing issue .. and plus i do like the look of a bit wider on the back..
Old Nov 28, 2008 | 08:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the front should be 4.5" of bs with that size and the rear should be 6. That will keep them sitting nicely. 5" would stick the rears out of the wheel well.
Old Nov 29, 2008 | 08:11 AM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
thats exactly what i was affraid of... well i g uess the search continues!! i do like the coys wheels C6 just got to find a supplier around here..
Old Aug 8, 2009 | 11:21 PM
dro561's Avatar
Car: 91 Camaro RS
Engine: Currently 3.1L v6 building 350
Try this i was looking at the same set up
http://www.rims-n-tires.com/rt_packa...taggeredMode=2
Old Aug 8, 2009 | 11:56 PM
firbster's Avatar
Engine: H.O. L69
Transmission: 5spd
i tried but it says session expired,, can you send me another link
Old Aug 9, 2009 | 12:01 AM
dro561's Avatar
Car: 91 Camaro RS
ok go to www.rims-n-tires.com pick your car in the section go to 18" rims it should be some of the first rims to come up click on it scroll down a little and there should be an option to see staggered click on it and you should be good
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kyleb24
Aug 15, 2015 08:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
