Zero offset crosslace on all four corners?
Old Mar 23, 2009 | 08:28 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Anybody (Firebird or Camaro) have pictures of their cars running 4 zero offset front crosslace (black or gold) wheels?
If so, please post. Thanks
Old Mar 23, 2009 | 09:47 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Zero offset crosslace on all four corners?
Mine weren't the crosslace, but that doesn't matter. Zero offset 16x8" works fine on all 4 corners.
Old Mar 23, 2009 | 03:24 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Thanks, I know - I want to see how they look though.
Old Mar 23, 2009 | 07:18 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Look up my 91 Formula.
Have 4 fronts on the car because the black cross lace were on my deceased 87 442.
Front looks normal obviously, it does give the back a little more aggressive stance. I like it and people, though few notice it and cant quite figure it out till they stare for awhile.
Old Mar 23, 2009 | 07:42 PM
Stephen's Avatar
Car: 87 GTA
Only pic I could find, showing out front wheels on the rear stuck out, before witching to my 17" Snypers.
Old Mar 23, 2009 | 08:23 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
...Actually, that pic was taken after the Snyper swap.
But, for the OP, fronts all the way around makes the car look right and balanced.
Old Mar 23, 2009 | 08:28 PM
Stephen's Avatar
Car: 87 GTA
You sure? The wheels seem to be in a bit too much, to be the Snypers? I know before I put the adjustable PHB on, the passenger side Snyper practically sit out past the fender lip. That seems too far in, to be a Snyper.
Old Mar 23, 2009 | 09:32 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
I would love to do this also. I want to get a set of those repro gold crosslace wheels all in the front offset. Then lower it, and put some fat meaty tires in the back. I think it would look mean as ****.
Old Mar 24, 2009 | 10:17 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
That's my plan, too. I don't know if I'm going to lower mine - at least not right away. My original gold crosslace wheels need to be refinished, so I figure I'll get the repos and offset some of the cost by selling the stockers.
Old Mar 24, 2009 | 10:22 AM
Stephen's Avatar
Car: 87 GTA
I've seen a lot of bad reviews on the repop crosslaces, about the polished lip having machining tool marks & the laces having bad/mismatching gold paint.
Old Mar 24, 2009 | 10:46 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
841LE has done this. It looks alot better
Old Mar 24, 2009 | 12:48 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I've read the bad reviews and I'm pretty certain they have to be better than the 21 year old wheels I have on there now. Worst case - I run the repos, keep the stock wheels and get them refinished at some point. From there I can either put them back on or put them away while the repos take the wear & tear.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
bschmale66853
Sep 30, 2015 08:11 PM
rb85TA
26
Sep 14, 2015 10:29 PM
