92 larger wheel width?
Car: 1992 B4C
Engine: L98 soon to be 383
i want to get a bit bigger wheel on the back of my camaro for a little more grip. not slicks (yet) just curious how wide of a wheel can i put on the back w/o modifying the wheel wells. not interested in big flashy rims just the biggest width i can fit on a stock rear end. i'm sure sombody has done it any help and suggestions would be greatly appriciated.
Re: 92 larger wheel width?
i don't think this question has ever been asked before............... try searching or looking at the post directly below yours called "biggest tires without tubbing" if that doesn't help..........
Car: 87 GTA
Yours is a very open-ended question.
It depends on what diameter you want....15"/16"/17"/18"? Lowered or stock height? How far in/out you want then to set? Which depends on the backspacing. What kinda tires are your goal? Slicks, short sidewalls for handling/tall sidewalls for cushion/tall sidewalls for drag racing?
With more information on what you are wanting for size, we can tell you more.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 87 GTA
Car: 1992 B4C
well the car will be stock height. im not looking to run slicks. i will put a stickyer tire on but i also want it to be wider. i want to stick with 16"s if i can 17"s are fine too. not to worried about handling as much as strip. my fronts are 245/50/16s and i wasnt planning on changing them. i dont want my rear wheels to stick out much farther from the car than the stocks do. to me just looks funny to have wheels sticking out far.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
the problem you seem to run into is no one really make 16 inch tires much wider than 255. You'd have to go to a taller side profile to get wider tread than 255 probably. I mean you could easily throw some truck tires on it... but I dont think that's the look you're after.
Car: 87 GTA
dbrochard
Sep 19, 2015 08:13 PM
