alignment
Old Sep 3, 2009 | 06:39 PM
mvd72786's Avatar
Car: 1989 Camaro IROC-Z
Engine: 305ci 5.0L (TBI to carb)
Transmission: manual
alignment
what are the different alignment specs between an 89 Iroc and a regular 89 camaro? I brought mine to the shop for an alignment, and after the alignment, there is a very distinct shake/shimmy over 45 mph. This is a project car, and i am still not sure if it is an original Iroc or a good imitation. I know that the specs for front end alignment are different between the Irocs and the rest of the camaros during that time, and mine was aligned to the regular camaro, not an iroc specs. THanks for your help.
Old Sep 3, 2009 | 06:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: alignment
i dont think there are different specs, i think the shop messed up or you have worn out parts somewhere. did the car shimmy before?
Old Sep 3, 2009 | 11:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: alignment
Usually a shake is a wheel balance issue, not alignment issue.
Old Sep 4, 2009 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: alignment
According to Chilton's, there's no difference 87-92. For the sake of info, there is a difference 82-86 for the Z28.
JamesC
Old Sep 4, 2009 | 10:28 AM
mvd72786's Avatar
Re: alignment
well no, the car never had a shimmy before yesterday when i got it aligned. And the printout that the shop gave me said on the top (which was computer generated by the shop):
"Cheverolet: Camaro: 1987-92: All Models except (1987-90) IROC-Z & (1987) Z28"
That is verbatim what the sheet says which lead me to believe that there may be different specs for a regular 89 and an 89 IROC.
I might take it back to the shop today and report my problem to see what they can do. Thanks for the help guys.
Old Sep 4, 2009 | 11:33 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: alignment
That's normal. When I got my 92 RS aligned last year, the printout said the same thing at the top. I'd have to check my shop manual, but I don't recall ever seeing any differences in the alignment specs between the RS/base coupes and the IROC/Z28 models.
If the car has a shimmy in it, its most likely a wheel balance/tire issue or a worn out bushing somewhere in the front suspension. Unless the shop forgot to tighten something. I had 7/10 lugnuts on my front tires loosen up once and it made for a real good shimmy in the front end till I tightened them back up.
Old Sep 4, 2009 | 12:05 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: alignment
Here at work I asked my co-workers about this and they tell me is from the balencing of the wheels that would make your car shake.
Tony.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
