Same Corvette wheels all the way around
Old Nov 18, 2009 | 05:09 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
I'm guessing there is a good reason not to put the same size Corvette wheels all the way around? I'd like to be able to rotate my tires.
Old Nov 18, 2009 | 08:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Same Corvette wheels all the way around
no reason your cant, its just that vettes come with staggered wheels and different widths, thats usually what comes in a set when you buy them
by all means, but 4 of the same wheels and tires, it wont hurt anything
Old Nov 27, 2009 | 12:41 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I'll be running 18x10.5 wheels front and back. I'll be picking them up Sunday afternoon.
Old Nov 27, 2009 | 07:50 AM
Car: 1986 Trans Am
Engine: 5.0
That's the size I want. I found a killer deal on some ZR1 wheels, but there are limited tire options for the rear
Those would be the only staggered wheels that I would have run.
Be sure to post up some pics
Old Nov 27, 2009 | 09:34 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
I have front C5 replica wheels, 17 x 8.5, at all four corners. Option of rotating tires is why I did it. By the way, tires ar 245 45 zr17. I will post some pics later. Dean
Old Nov 29, 2009 | 11:47 PM
Car: 1987 IROC-Z
Transmission: TH350
Limited??? There are a lot of tires that fit a 17x11 wheel. You just have to be prepared to get out the hammer and maybe welder to make them fit.
Staggered??? Would you be planning 17x9.5 in front and 17x11 in back? I say keep things the same all around or you will never be able to rotate them. That's one of the things I hate about the stock wheels... you can't rotate them and if you have directional tires, you can't even swap sides without it being a big hassle.
I won't have the wheels bolted onto the car for a while, but I may be able to put them in the wheel wheels were they will probably be sitting just for some pics.
Mahhh... those are baby wheels.
If I change wheels on any vehicle it has to be for a reason, and not just because it is different. It has to serve a purpose (like wider rubber for needed traction) otherwise it seems to be a waste of money that could go towards the motor or something. Maybe I just think this way because of the really tight budget I'm on...
Old Dec 2, 2009 | 03:51 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I have C5 18" all around.
[IMG]http://[IMG]http://i941.photobucket.com/albuCorvette Wheels Standard Sizes:
Cast Aluminum
Front: 17 x 8.5 Tire size: P245/45ZR-17
Rear: 18 x 9.5 Tire size: P275/40ZR-18
Bolt pattern 5x4.75" (same as 5x120.65mm)
Front offset=58mm, Rear offset=65mm
Z06:
Forged Aluminum
Front: 17 x 9.5 Tire size: P265/40ZR-17
Rear: 18 x 10.5 Tire size: P295/35ZR-18
C5 Corvette Wheel Hard Core Data
C5 Corvette Wheels Weight by brand and type
19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon
22 lbs, front; 29 lbs, rear - 97-99 OEM wagon
17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium
17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium
18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish
17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps
16 lbs, front; 20 lbs, rear - 01 OEM standard high polish
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun
24 lbs, 18x10.5 - 00+ repro high polish
28 lbs, front; 32 lbs, rear - Z06 chrome repro
23 lbs, front; 26 lbs, rear - Z06 chrome repro
23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished
20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear
22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center
27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center
24/25 lbs - Z07 wheel weight, front
28 lbs - Z07 wheel weight, rear
ms/ad252/LarryL109/18x4.jpg[/IMG][/IMG]
Old Dec 2, 2009 | 05:33 PM
Car: 1987 IROC-Z
Transmission: TH350
Maybe it's just me, but why do people only post the diameter? That doesn't mean much... people have already fit 20" wheels on these cars without issues. It's the width that makes it mean something. I mean, to play dumb I would now be assuming those people have 2D wheels which means they have no (conventional) tires. Same thing angers me when people post the style of wheel I'm looking for in a sale ad, but they only give the diameter. The width of the wheel is probably thee most important measurement of a wheel. In my opinion, it is has the largest impact on tire selection, and on available traction. What I also don't understand is that when I later e-mail people asking for the width I often have to ask 3 or 4 times before they finally answer me, and often times they never do... they just keep giving me the diameter.
Don't get me wrong, I'm not posting this to flame LarryL's post. I'm posting this because when people talk about rotating wheels/tires, wheel width and backspacing become major factors. I mean, with a giant hammer and some effort, you can make 11" fit in the back of these cars, but getting an 11" to fit in front is going to be pretty difficult without insane amounts of tire rub. The other thing is the C5 corvette itself came with 3 different style of wheels. The wagon wheels, the thin spoke wheels, and the Z06 wheels. The all also came in two different diameters (17 and 18) and three different widths (8.5, 9.5 and 10.5).
Old Dec 2, 2009 | 05:40 PM
Car: 1986 Trans Am
Engine: 5.0
I agree 100%. I had to e-mail someone on Craigslist 3 times to get the width. I finally got him to send me a pic of the inside of the wheel with the measurements. They were 18x9.5 polished for $60 for the pair.
Old Dec 3, 2009 | 01:07 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I did not post a size because from my experience they all fit with stock (vette)tires and 2" adapter. I don't believe in choping or hammering up the car for a set of wheels and tires. The only issue (I have seen)is the rear wheels left to right clearances. Sometimes the rear is off as much as 2" to one side, so you must be careful with 275/40/18. Do a search there is plenty on this. The sidewall size can change the whole setup and look. On my 84 TA I have 265/35/18 front and 285/30/18 back. I did not like the steam roller look in the back. On my 69 camaro I run the 17/18 stock zr tire setup it looks great IMO. If you run ZR tires they must be installed in the rotational direction in which the tire turns, so you can't switch left to right side with remounting the tires. There is another thing which has nothing to do with fitment its tread design. The tread design can change the look of the car also and the driving noise. I know a lot of people go for width, if its just for looks its your call, IMO if you get too much traction with our usless (for power) rears you tear them apart.
Drone358
Dec 10, 2015 08:16 PM
Lanz06
Sep 14, 2015 07:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
