Cheap 19in wheels
Old Nov 10, 2009 | 07:54 PM
bitchin_camarAA's Avatar
Cheap 19in wheels
i would like to get 19in wheels 10inches wide....deep dish. does anyone know a good website for cheaper wheels like 2000 or less or a good forum to find sweet used wheels? -thanks
Old Nov 10, 2009 | 09:23 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: Cheap 19in wheels
the corvette wheels are kinda played, but they do have some nice deep dish versions out now on e-bay... worth checkin out considering they're well less then a grand...
Old Nov 11, 2009 | 04:37 PM
oh yeah... ebay haha thanks il check it out
Old Nov 11, 2009 | 04:46 PM
  • (2) Front 18 x 9.5" Wheels and (2) Rear 19 x 12" Wheels
  • +40mm Front Offset
  • +59mm Rear Offset
you think those rears would fit flush with that offset?
Old Nov 11, 2009 | 07:27 PM
1988-305-tbi's Avatar
youll need spacers/adapters
Old Nov 15, 2009 | 05:05 PM
can you explain me the whole backspacing thing? i always went buy positive or negative offset
Old Nov 15, 2009 | 05:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
  • +59mm Rear Offset
backspacing and offset are 2 different ways of measuring the location of the mounting surface of the wheels.
5.5" of back spacing means there is 5.5" from the inside lip of the wheel to the hub mounting surface.
offset is similar. The +/- is the distance from the center of the wheel that the mounting surface is. + is toward the outside of the wheel, - is the inside.
You will need spacers to get the outside of the wheel to be flush with the outside of the car.
The rear wheels you have listed will not fit the car without a mini-tub, unless they stick out from the side of the car over an inch.
Another important thing is the wheels width. A 18x9.5" wheels DOES NOT measure 9.5" wide, its more like 10.5". The nominal measurment is form the inside of the bead seats, not the actual outside of the rim.
So the 18x9.5 will be 10.5" wide +/- and the 19x12 will be 13" wide +/-
Old Nov 16, 2009 | 12:46 AM
ok cool thankyou i understand i was looking at these in 8 or 9 up front and 10" in back and 3.75 backspacing
http://www.newstalgiawheel.com/wheel...ubcat3=1064101
Old Nov 16, 2009 | 06:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
your backspacing is wrong, big time!!!
for the front, i would do 4.5" of backspacing with the 8" and 5.5 with the 9". That will place the wheels just a hair further out than stock, but keep them nicely tucked under the car.
for a 10" rear, 6.5" of back spacing, may need to do some hammering in the wheel well, maybe cut off the bumpstop bulge. If you take off a wheel and place a straight edge across the drum/rotor face, and measure back you will see what kind of space you have and where you will have to hammer/trim
with 3.75 backspacing, the wheels will stick way outside the wheel wells.
make sure you do all your research and measure a bunch of times before you drop that kind of money on wheels.
Old Nov 17, 2009 | 04:33 PM
ok thanks i see what you mean il do the measuring... and i dont plan on getting these wheels til next summer at the earliest so i have plenty of time to research..... what i was thinking with 3.75 backspacing was that would have the biggest lip. and i want them to be flush with the body so if they stick out i can roll the fenders a lil and also il have negative camber when i lower it... how many inches would you guess those wheels would stick out with 3.75 backspacing?
Old Nov 17, 2009 | 07:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
over 2" in the rear, totally unacceptable and illegal most places
The only other way to do it wold be to order an aftermarket rear in a shorter width, or have your axle shortened. But thats not cheap and a waste.
Old Nov 18, 2009 | 04:57 PM
i see i could deal with an inch or inch n half, camber and fender roller would fix that i dont know bout 2inches tho
Old Nov 18, 2009 | 05:06 PM
id be fine with the wheels sticking out like this
but id prefer this
Old Nov 18, 2009 | 08:10 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well, the first pic looks like totaly crap, but the 12's will stick out much further than that.
the last pic is sweet, and totally doable with the right wheel
Old Nov 18, 2009 | 08:30 PM
RU1NER's Avatar
2nd picture is sickness (hehe). Anyways the 19x11 corvettes fit the rear with a little beating right?
Old Nov 19, 2009 | 04:52 AM
yeah i got that pic from his post on here...
i dont mind them sticking out a lil like the 240 but what offset you think id need with a 10in wide wheel to fit like the 2nd pic? ...i guess i could just ask him what offset... he has haha
Old Nov 27, 2009 | 10:26 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
www.oewheelsllc.com Plenty of wheels to look at here. Good prices too, Dean
Old Dec 3, 2009 | 06:31 PM
cal30_sniper's Avatar
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Have you thought about rubbing in the front wheel wells with rims that stick out like that? I ran 15x8" Torq thrusts on mine for a little while with 3.75" backspacing. The rear was livable, they stuck out about 1/2" too far, but from most angles they looked alright, would have preferred them flush with the body though. The front, however, were a different story. With a 3.75" backspacing (-13mm offset for an 8" rim), the rubbed like crazy at anything past about 1/2 to 3/4 lock. And remember, that's with an 8 inch wide rim. Anything wider in that backspacing would only be much worse. It really got to be unbearable after a while, so I pulled them off and went with 18 inchers in the proper offset. Don't go cheap on the rims and get the wrong offset/backspacing, you'll regret it later.
And just my own personal opinion, anything that sticks out past the top of the fender looks way too red neck on our thirdgens. I've seen a few, very few cars that could pull it off, but most just looked cheap. Set it up right and you'll have something that looks absolutely awesome, drives great, and handles much better than factory. Don't forget, running a rim with significantly less backspacing to move it further out really plays heck with your suspension geometry, and can have a huge negative impact in handling and responsiveness.
Just my $.02, I've been around the block a time or two with these third gen wheel setups, and I'm telling you, do it right the first time or you'll be doing it again later.
-Levi
Last edited by cal30_sniper; Dec 3, 2009 at 06:32 PM. Reason: is red neck really an edited word? wow.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
