will these rims fit my GTA
Car: 91 formula
Engine: 350 tuned port. bolt ons
here is the details 15x8,..5x4.5.in bolt circle, backspacing. rim diameter 15 inch. rim width 8.00 inch. backspacing 3.750 inch. offset mm -19.00mm they are from summitracing part no 3525812 here is a picture.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: will these rims fit my GTA
wont work, you need 5x4.75 bolt spacing and sometihng like 4.5" of backspacing or 0 offset.
Car: 91 formula
thanks guys I will keep looking. I really want black rims like the ones in the pic.
Car: 86 Trans Am
Car: 91 formula
im trying to go with a nascar kind of look with the white raised letter tires and all. But my second option is just going with the black gta stock rims.
Car: 87 GTA
Car: 87 T-Top GTA
But with 0mm offset at the rear, wont the rear tires rub on the fender if you were to hit a bump?
Car: 87 T-Top GTA
Still thinking of using the Year One "bandit" rims on my car!!! But I would feel much better if I could find a pic of a 3rd gen with those rims on it before I go and buy them!
The rims are too expensive to buy if it makes the car look stupid with them on!!!
Car: 87 GTA
Want a cool tip to make it all look right? Put the fronts on the rear & the rears on the front, but with those aluminumm drum factory spacers. That'll give the narrow wheel up front, wide rear wheel look out back. Without the spacers, rears will rub up front if you try to turn ANY.
Car: 87 GTA
I know somewhere on TGO, I've seen pics of 3rd gens with the Bandit wheels on. I know I even did a Photoshop at one time, but apparently I deleted it after there were pics of real 3rd gens with them on.
Street Lethal
Apr 30, 2019 12:14 PM
