picked rims, will they work? help
Old Dec 24, 2009 | 03:44 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
so im looking at a set of momo rims, think theyll look really good
does a 5x120 bolt pattern fit right on a 3rd gen ir what?
and if the stock rims are at like +10 offset (correct me if im wrong plz)
and these are +35, a 25mm spacer will make it all work yes?
thanks guys
happy holidays oh and there 17x8
Old Dec 24, 2009 | 07:42 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Re: picked rims, will they work? help
thanks guys
cant help you with the offset but the bolt pattern should work
Old Dec 25, 2009 | 12:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would not take a chance on 120mm bolt circle wheels when the factory wheels are on a 4.75" circle. 4.72" is not close enough to 4.75" in my opinion. I think that you would have centering issues.
Old Dec 25, 2009 | 01:18 PM
Twin_Turbo's Avatar
4.75 is 120.65mm, 120 mm is a BMW size and it will bolt right up. Only a .325mm difference per stud. I have M6 rims, 19x8.5 and 19x9.5 w/ 20 ET and they bolt up.
Old Dec 25, 2009 | 02:17 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It's not exactly right but a lot of people do it anyway.
I personally would be comfortable with doing it.
Old Dec 25, 2009 | 02:31 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
yes a 25mm spacer will be perfect. more commonly a 1" spacer will be used though because 1" = 25.4mm
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
