will 4th gen wheels fit on a 3rd gen or do you need adapters
Old Jan 1, 2010 | 02:10 PM
ghost stripes's Avatar
i did a search and found pics of it done but no one stated how they done it
Old Jan 1, 2010 | 02:18 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Re: will 4th gen wheels fit on a 3rd gen or do you need adapters
yes you need adapters for front and rear or you can swap a 4th gen rear end in there but you still need apapters for the front. again
Old Jan 1, 2010 | 02:20 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
not adapters, spacers. 2 inch in the rear and i can't remember the front but you need spacers. the wheels share the same bolt pattern/size
Old Jan 1, 2010 | 02:24 PM
ShMaCk2004's Avatar
spacers/adapters same difference
Old Jan 1, 2010 | 02:31 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
^^What they said and I think It's 2in spacers on all 4 corners.
Mark.
Old Jan 1, 2010 | 02:33 PM
ShMaCk2004's Avatar
Mark.
no its less on the rear. like 1 3/4 or something
Old Jan 1, 2010 | 03:04 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Ops I was wrong they need 2 1/2in spacers all around. Sorry.
https://www.thirdgen.org/4th-gen-wheels-3rd-gen
Old Jan 4, 2010 | 04:57 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Wow. First of all you will need Wheel adapters not spacers, there is a difference. The size of the adapters will depend on what offset your wheels are. I'm running 2" adapters all around with 17x9 +46 SS wheels with 285/40/17 wheels, stock disc/drum brakes. As you can see in the flush wheels/ dumped cars thread they are damn near perfectly flush.
Old Jan 4, 2010 | 12:24 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
adapters and spacers are the same thing. i call it an adapter when you change the pattern from like 5X5 to 5X4.75, and a spacer when you leave the pattern alone and increase space
Old Jan 4, 2010 | 12:49 PM
DBLTKE's Avatar
Engine: LB9, LB9
No, you are wrong. Slip on wheel spacers are not the same as bolt-on wheel adapters, plain and simple. Spacers are fine if you want to move the wheels out about a 1/4" or less but any more than that and you are flirting with danger. It puts the stress too far outboard on the studs and can cause them to shear off. I have seen this happen many times at the drag strip that I work at. Adapter don't have this problem because they have pressed in studs and literally act as if the wheel has less offset.
Old Jan 4, 2010 | 10:59 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
so you're saying there's no such thing as a "bolt on" spacer? i know the limits of slip on spacers, just like adding shims/washers on anything mechanical or structural.. obviously too much is a bad thing. it's an iffy and pointless debate. personally i interchange the words every time
Old Jan 5, 2010 | 07:56 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
^^Exactly. That's what you need to put 4th gen wheels on a 3rd gen car. Bolt on spacers, because the bolt pattern is the same but the offset is different.
Mark.
Old Jan 5, 2010 | 07:59 AM
motorman350carb's Avatar
Car: 1989 iroc z28
Engine: L98 350 carb
Transmission: built 700r4
this site helped me out when trying to find info on all camaro rims http://www.tacreationsusa.com/camaro_wheels.htm has lots of info tell you what years would work and from new to old what spacer plat size you need and where to buy it
Old Jan 8, 2010 | 02:17 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
why exactly is it that we need adapters/spacers? Is it because the tires rub? or does it just look funny???
Old Jan 8, 2010 | 04:32 AM
DBLTKE's Avatar
Engine: LB9, LB9
On the rear I don't think you actually need that much spacer. When I test fitted my SS wheels they almost seated on the hub. It has to do with the backspacing, There's things inside the wheels well that make contact with the wheel/tire thus not allowing it to turn or even bolt up. Up front everything is a pretty tight fit, I'm not sure if you can use anything smaller than a 2" spacer in order to clear everything up there with a 17x9 +46 wheel.
Old Jan 8, 2010 | 04:52 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Mainly clearence issues and the difference of at least a 40mm offset... Just imagine your wheels sucked into the fenders another two inches and thats pretty much what it would look like if you didnt have any clearence issues and didn't use spacers... Ridiculous... haha
Old Jan 8, 2010 | 02:31 PM
HCR13's Avatar
Car: 1987 Trans Am
haha, thats what I thought, I just wanted to make sure. In case of an "emergency" where I didn't have stock wheels, I can bolt up the 4th gens and move the car around...
Old Jan 8, 2010 | 02:42 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Nope. They won't work on the front without spacers, I tried. I never tried the rear.
Mark.
Old Jan 9, 2010 | 05:43 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
Mark.
You'll be able to bolt emm to the rear, but you wouldnt be able to get it over the hub in the front...
If for some odd reason you decide to do that for ***** and giggles, take pics... **** would be hillarious! haha
Old Jan 14, 2010 | 04:22 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Interesting thread.
Am running an 82 Bird with 4th gen wheels. You will need 2" more on each end. Because i wanted the 4th gen wheels AND disc brakes i installed a 4th gen rear end and had to use 2" BOLT ON ADAPTERS in the front to get the proper fit without any rubbing anywhere.
Old Jan 15, 2010 | 12:06 AM
DuBree 87's Avatar
My god, you people have made me jump back and forth as i read down the forum.
--"OH OK, so i do just need a spacer....wait a sec... an adapter now? What the hell, OH A BOLT ON SPACER!!!"-- Who cares what the **** they are technically called. They both change the offset of the wheel!
Old Jan 15, 2010 | 12:13 AM
DuBree 87's Avatar
......good thing to have continued reading.... just looking for some cheap 4th gen rims to save the Iroc's for showroom and plan on painting them black so the unpleasant look blends in better.
I'llrocya
Feb 2, 2016 11:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Omega
Oct 1, 2015 02:20 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
