2 or 2.5 in spacer
Old Feb 6, 2010 | 07:53 PM
purple98haz28's Avatar
2 or 2.5 in spacer
im sorry ive searched endlessly and now im more confused i want to put some 17x9.5 rims that fit 4th gens on my 85. do i need a 2 in or 2,5 in spacer i hear both which is safest and looks best thanks... i promise i searched lol
Old Feb 6, 2010 | 07:59 PM
Stephen's Avatar
Car: 87 GTA
Re: 2 or 2.5 in spacer
WHICH 4th gen rims? They aren't all the same.
http://www.skulte.com/adapterfaq.html
Old Feb 6, 2010 | 08:14 PM
here is a link to the rims http://www.oewheelsllc.com/Camaro-Wh...02383-3-1.html
Old Feb 6, 2010 | 08:19 PM
Stephen's Avatar
Car: 87 GTA
Find out what the offset is & the link I already gave you, should tell you what you need.
Old Feb 7, 2010 | 01:46 AM
ok that page says 54 mm offset is 2.25 in spacer... thanks thats bookmarked now
Old Feb 19, 2010 | 03:57 PM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
I know it says 2.25" adapters, but would 2" adapters work? What would be the widest size tire for the rear...275?
Old Feb 19, 2010 | 04:04 PM
Stephen's Avatar
Car: 87 GTA
2" adapters are what are usually used, just to get all 4 the same sized & they can go anywhere.
As for tire size....On what wheel? On what rear axle? You willing to do any mods to make what you want fit?
Old Feb 19, 2010 | 08:29 PM
strc09's Avatar
The car is lowered and I'm using the stock 9-bolt rearend in the car for now until I can afford the swap to a 12-bolt. I'll be using the same wheels purple posted the link for a few posts up.
Old Feb 19, 2010 | 09:07 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Depends on your sway bar up front. I have to run a 2.1/4" because of a crappy sway bar in the front, The rear you may have to measure because I have a 4th gen rear and 54mm fits perfect.
4th gen axles are 1 11/16" longer than 3rd gen axles. Right off of Summit using Moser direct fit axles.
4th gen
http://www.summitracing.com/parts/MSR-A102805/
3rd gen
http://www.summitracing.com/parts/MSR-A102604/
4th gen axles are 32" and 3rd gen axles are 30.313"(30 5/16")
If it's a 9 bolt then it's a different animal. They have different axle lengths on each side
Old Feb 20, 2010 | 04:28 PM
strc09's Avatar
Thanks for the input.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
