widest tire?
Old Feb 9, 2010 | 07:20 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
widest tire?
So my trans am has a rear end from a camaro ss 2002. The tires stick out about 3 inches each side. If anyone has a similiar setup, whats the widest? Thanks!
Old Feb 9, 2010 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: widest tire?
holy crap! if the tire is 3" outside the car, im sure you could fit a 335 without any wheel well work. It will look like total hell, but it will probably fit
Old Feb 9, 2010 | 08:04 PM
Engine: 383 Stroker
Transmission: t-56
Re: widest tire?
the car isnt close by. I cant remember if it was 3 inches each side or 3inches total. If it stuck out 1 1/2 each side what would be the widest?
Old Feb 10, 2010 | 09:10 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: widest tire?
well it does really depend on what width wheel you use and how far its actually stick out
Old Feb 10, 2010 | 09:15 AM
exarkun1178's Avatar
Re: widest tire?
not to hijack, but. i have 89 stock iroc 15 inch wheels. right now i have 255 60 15 bf comp t/a. i like the beefy and very wide look, however- my application calls for r compounds. is any one running r888 or Ao48? id even consider RT-615 .what size is the largest/widest i could fit?
Old Feb 10, 2010 | 09:19 AM
goose88's Avatar
Car: 88 camaro
Engine: 383 stroker
Transmission: th350
Axle/Gears: stock rear end with moser 411s
Re: widest tire?
first your 4th gen rear is wider than a 3rd gen. so if you pu your stock wheels on a fourth gen rear it will hang out the fenders. you can safely run a 285 on the rear. but you need wheels with te corect ofset from a 98 or up fourth gen
Old Feb 10, 2010 | 09:23 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: widest tire?
Try a set of wheels from a 4th gen they should fit perfectly! That will be the type of offset you need....
Old Feb 10, 2010 | 09:25 AM
goose88's Avatar
Car: 88 camaro
Engine: 383 stroker
Transmission: th350
Re: widest tire?
you definetly need fourth gen wheels but i am not shure if the 93-97 have the same ofset as the 98-02 i would just double check
Old Feb 10, 2010 | 09:54 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Re: widest tire?
Yes, they do... car would look sweet with 18x10.5 Zo6 wheels
Old Feb 10, 2010 | 09:59 AM
Engine: 383 Stroker
Transmission: t-56
Re: widest tire?
i have gta wheels... id hate to rid them
Old Feb 10, 2010 | 10:15 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Re: widest tire?
At this point the only thing you can do is swap back to the 3rd gen rear end,swap the LSD and gears over be sure to use 89-92 axles(28-spline) the rear ends are 2" different in length.
Old Feb 10, 2010 | 10:25 AM
Engine: 383 Stroker
Transmission: t-56
Re: widest tire?
can i ask why? I already have tires on my car and everythings fine... just need new tires now.
Old Feb 10, 2010 | 10:34 AM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
I have 315s on 11" wheels and they are almost 1/2" in & not sticking out. And I'm not the only one here. The wheels determine where the tires end up, regardless of the rear end width.
Post up a pic of you tires "sticking out 3 inches".
Even with the GTA rear rear (not front wheels on the rear) they should end up flush with the outer fender lip & not stick out.
There is a difference between SITTING out & STICKING out. I suspect that your definition of "sticking out" is different than what most people would call it.
Here's mine.....
And here is a Camaro with a 4th gen rear end & stock rear offset 16" 3rd gen wheels (the same as your GTA wheels).....
Old Feb 10, 2010 | 04:59 PM
Car: '88 Trans Am
Engine: 5.7L TPI
Re: widest tire?
4th gen rear in a 3rd gen retaining the stock 3rd gen wheels look funny out back especially from behind,if you like it like that by all means go for it.
Old Feb 10, 2010 | 05:16 PM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
Why does it "look funny out back especially from behind"? Does the blue Camaro I posted above, look funny?
Old Feb 10, 2010 | 05:40 PM
Car: '88 Trans Am
Engine: 5.7L TPI
Re: widest tire?
To me it does...looks like the wrong wheel offset for the car...
Too much inner wheel well not being used.......
Old Feb 10, 2010 | 08:20 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: widest tire?
My back spacing is off a little but I don't have a problem with it. Those are 295/50r15s in the rear on a 8in. wheel.
Old Feb 11, 2010 | 10:59 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: widest tire?
I think there's a problem with that blue camaro and a HUGE problem with the red one! The blue one I'd be okay with if the rim were 10 or 10.5 inches wide so the wheel well was completely full. it looks strange having "skinny" tires being pushed out that far. Ronusmcmma, your camaro is otherwise beautiful, but don't those rear tires slam your fender when you launch?
Old Feb 11, 2010 | 11:09 AM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
The blue Camaro really fits the "wide track" Pontiac slogan though, huh?
Old Feb 11, 2010 | 12:11 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Re: widest tire?
I just recently realized that Pontiac's "Wider is Better" campaign might've been responsible for Pontiac picking up a lot of female buyers around that time. hehe
Old Feb 11, 2010 | 06:50 PM
Engine: TBI,5.0
Re: widest tire?
When I finally do decide to replace the wheels on my car I will have the correct back spacing. I made a mistake with my first try at wheel fitment. No the rear tires don't bottom out at any time because Im running a set of independently controlled rear air shocks rated up to 1000 pounds . There made for towing or caring heavy loades. There's very little give to them.
Old Feb 11, 2010 | 11:22 PM
Engine: TBI,5.0
Re: widest tire?
OK, decided to fix the rear backspacing on my car. Been looking at these wheels in a 15in. by 8in. rear with a 5.5 backspacing to compliment a 295/50r15 tire. They offer the same for the front but with a 4.0 backspacing. What do you think?
I need to fix this=
Old Feb 11, 2010 | 11:35 PM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
I need to fix this=
I wouldn't go THAT deep. I like 0 offset wheels. In other words...Center of the wheel being the tire mounting surface.
I ran 17" x 9" 5" bs front & rear with zero clearance issues. For a 8" wheel, I'd go 4.5"bs (4" is the center of where the tire seats, the .5" comes from the rim lip).
Old Feb 11, 2010 | 11:41 PM
Engine: TBI,5.0
Re: widest tire?
I did not mean to high jack his thread so started a new one. Always nice to hear from you Stephen.
Old Feb 24, 2010 | 12:45 AM
Engine: 383 Stroker
Transmission: t-56
Re: widest tire?
SO do you think i could run p295's?
Old Feb 24, 2010 | 07:45 AM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
Need more info (on the tire size AND wheel to be 100% certain) but yes...A 295 width tire can fit very easily under a 3rd gen fender.
Old Feb 24, 2010 | 10:01 AM
slow84ta's Avatar
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
Re: widest tire?
I'll looking to run 315/45/16 on a 10.5 rim, I'm assuming with those aboved mentioned offsets no mini tubs are needed?
What are the stock 3rd gen offsets?
Old Feb 24, 2010 | 11:37 AM
Stephen's Avatar
Car: 87 GTA
Re: widest tire?
Our front 16x8" 0mm offset front rims would have 4.25" of backspacing.
The rear 16" x 8" 16mm positive offset rims (16mm/25.4 = 0.63") have about 4.9" of backspacing
Where are you going to find a tire that size?
Old Feb 24, 2010 | 11:59 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Re: widest tire?
Hey Jim! I don't see that size existing on Tire Rack. Also, that would be a 27" diameter tire. I'm thinking about going with a 27" tire also, but I wanted to make sure you take overall diameter into account when selecting a size. What style rims were you gonna run?
Old Feb 26, 2010 | 02:44 PM
slow84ta's Avatar
Engine: built 406
Re: widest tire?
315/45/16 M/T ET Street
http://www.summitracing.com/parts/MTT-3795R/
I'm gonna get 16 inch rims like my stock ones, widen them to 10-11 inch in width. It looks like 11 would be better.... a few years down the road.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
