Fixing my rear backspacing
Old Feb 11, 2010 | 11:28 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
OK, decided to fix the rear backspacing on my car. Been looking at these wheels in a 15in. by 8 in. rear with a 5.5 backspacing to compliment a 295/50r15 tire. They offer a 15in. by 7in. for the front but with a 4.0 backspacing.. What do you think?
I need to fix this= Thats a 295/50r15 on a 3.75 BS rear on a 15 by 8in. wheel
Old Feb 11, 2010 | 11:40 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Fixing my rear backspacing
those "prostar" look-a-likes are nice looking but even heavier than a stock aluminum wheel. i highly recommend the Weld prostars. with a 8" wheel 4" backspace looks good. i guess you have a 3rd gen rear? also that 295 50 15 will look better on a 10" wide rim.
Old Feb 12, 2010 | 12:02 AM
Engine: TBI,5.0
Yes that's a 3rd gen rear. When I first started fixing up this car I really had no idea about back spacing so just went with a wheel I liked. Turned out to only be offered in a 3.75 bs for a 15 by 8 in wheel. So Ive decided to get it fixed. I did some measuring with a tape and looks as if I am going to need the extra 1.75 that a 5.5 bs offers to get that 295/50r15 tire to fit.So I its going to be 15x8 ,5.5bs with 295/50r15s
Old Feb 12, 2010 | 12:35 AM
i would go 15x10 with 5.5" bs. here is a pic of mine but its a 4th gen rear. 15x10 with 7.5" bs. could have tucked it in more with 8.5" bs and some hammering but still looks good.
Old Feb 12, 2010 | 12:36 AM
sorry its not the greatest pic
Old Feb 12, 2010 | 11:37 PM
Engine: TBI,5.0
I decided to go with a 15 by 8in. rear wheel . Dose any one else have photos of a 15 by 8in. wheel with a 5.5 bs. and maybe a 295/50r15 tire would be nice?
Old Feb 13, 2010 | 11:04 PM
Engine: TBI,5.0
OK, Decided to go with the Weld Prostars.Still would like to see some photos please.
Old Feb 14, 2010 | 12:17 AM
here is some more pics of mine if that helps any. the closest interference is the bump-stop area and maybe the LCA
Attached Thumbnails Fixing my rear backspacing-wheel-top.jpg   Fixing my rear backspacing-wheel-susp-int.jpg   Fixing my rear backspacing-wheel-rear-close.jpg
Old Feb 14, 2010 | 12:23 AM
and one more
Old Feb 14, 2010 | 09:43 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
At least yours aren't like this...
Old Feb 26, 2010 | 10:24 AM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
you get those rims yet?
Old Feb 26, 2010 | 06:24 PM
Engine: TBI,5.0
No the Weld Prostars are going to have to wait until after moneys not so tight. I am going to put some 255/60r15 on the rear when the 295/50r15 need replacing. That will bring in the rears at least 1in.each side, then I'm thinking 4.5 bs on a 8in. wheel in order to get the full 1.75 needed to bring them in with the 255/60r15 tire. Its just that Ive been looking at some of the other cars here and a slightly thinner tire looks pretty good . Anyway a 255/60r15s not all that thin.
Old Feb 26, 2010 | 06:36 PM
Stephen's Avatar
Car: 87 GTA
Whe I had 9" rears, I had 5" bs with plenty of room inside & they were in from the fender lip by about 1/2" - 3/4".
Going to 11" with 7" bs, I had to a "little" bit of cutting & hammer work, but it was WELL worth the extra work.
Don't go down to a "weenie" 255 in the rear. You'll regret it!
Old Feb 26, 2010 | 06:38 PM
at least a 275mm
Street Lethal
Apr 30, 2019 12:14 PM
mustangman65_79
Apr 14, 2017 05:37 PM
neekolzun
Aug 24, 2015 04:59 PM
kah992
Aug 19, 2015 02:55 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
